Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Using user data string to load texture files
4 REPLIES 4
javiertoledo
684 Views, 4 Replies
Hello.
We assigned string attributes to the primitives that store the texture path and filename. Then we connect a user string data with the attribute name and connect it to the filename port of the texture file. It should work but it's not..
Any ideas?
Thanks!
Labels (4)
4 REPLIES 4
in reply to: javiertoledo
You're trying with <attr:texture_name> in the filepath?
https://docs.arnoldrenderer.com/pages/viewpage.action?pageId=40110953
javiertoledo
Humm, I was using the user data node, I'll try with that expression.
Thanks!
javiertoledo
That worked as a charm, thank you!
I wonder why the user data node didn't work. It works for every other data type but not on strings, maybe I'm missing something...
Cheers
afair, strings aren't resolved during shader evaluation
Please accept the answer (from Nic) if it helped
// Stephen Blair
// Arnold Renderer Support
