Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
user_data returning null
3 REPLIES 3
227 Views, 3 Replies
I am trying to get an integer value into a shader. No matter what I do it is always returning default values. Attached is what I assume is everything correct. I can't find a way to debug this with arnold, as it does not seem to mention anything about it in the logs.
Tags (2)
Labels (2)
3 REPLIES 3
nic.birmingham
https://docs.arnoldrenderer.com/display/A5AFHUG/User+Data
you should Add Arnold Properties to the geo (tab > Arnold > Add Arnold Properties). Go to the Attributes tab and type primitive_id into primitive Attributes.
in reply to: nic.birmingham
It is already there and I have been exporting all attributes
Actually you're right, putting an asterisk doesnt export all the attributes for some reason, but naming each one does. Thank you
