Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
USD Rendering AOVs to separate files
2 REPLIES 2
donat
199 Views, 2 Replies
I'm trying to render aovs as separate files in Houdini. Rendering aovs as channels of a single exr file works fine.
I'm first exporting my usd stage to disk. This usd contains multiple render products, each of the render product define a filename for the exr files. When I 'kick' that usd file, only one exr file is written to disk. It seems kick only sees the first renderproduct and ignores the other ones. I would have expected kick to process every renderproduct.
Here's an excerpt of the usd file :
        def RenderProduct "renderproduct"
            custom string arnold:driver = "driver_exr"
            rel orderedVars = </Render/Products/Vars/direct>
            token productName.timeSamples = {
                1: "//server01/shared2/projects/Xavier_RD_2024/scenes/Test/Test001/FX/work/Test001_donatUSDexport_v001.renderproduct_edit2.MyDirect.0001.exr",
            token productType = "raster"
            int2 resolution = (1920, 1080)
        def RenderProduct "renderproduct2"
            rel orderedVars = </Render/Products/Vars/specular_direct>
                1: "//server01/shared2/projects/Xavier_RD_2024/scenes/Test/Test001/FX/work/Test001_donatUSDexport_v001.renderproduct_edit3.MySpec.0001.exr",
Regards
Tags (1)
2 REPLIES 2
Stephen.Blair
in reply to: donat
Works for me.
// Stephen Blair
// Arnold Renderer Support
donat
in reply to: donat
Thanks Stephen. My issue was that only one of my render products was referenced in the render settings
