Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
unable to load driver_houdini.so
3 REPLIES 3
JoHtz
762 Views, 3 Replies
I want to try arnold to see if it suits our production needs, but when I try to render it seems not to find "driver_houdini.so" , altough it is in the arnold plugin directory. Can someone tell me how to fix this?
I'm on centos8.
00:00:00   103MB WARNING |   unable to load dynamic library /root/htoa/htoa-5.3.0_r233605f_houdini-18.0.499/htoa-5.3.0_r233605f_houdini-18.0.499/arnold/drivers/driver_houdini.so: libHoudiniUT.so: cannot open shared object file: No such file or directory
00:00:00   103MB ERROR   |  [ass] line 26: node "driver_houdini" is not installed
00:00:00   104MB WARNING | rendering with watermarks because the skip_license_check option was enabled
00:00:00   118MB ERROR   | [aov] output references a non-driver node: /out/arnold1:iprsocket
00:00:00   118MB ERROR   | [aov] no valid output statements found: could be a progressive render without a display window
00:00:00   118MB WARNING | failed to launch bucket workers:  received abort signal
Tags (1)
Labels (1)
3 REPLIES 3
Stephen.Blair
in reply to: JoHtz
It looks like libHoudiniUT.so is missing.
driver_houdini.so depends on libHoudiniUT.so
Can yhou check or post your Houdini environment? eg Help > About Houdini > Show Details
// Stephen Blair
// Arnold Renderer Support
dfransolet
in reply to: JoHtz
Hi, it's an old topic but we have the same problem here. I have joined the Houdini env details txt.
Thank in advance for the help 🙂
Stephen.Blair
in reply to: dfransolet
I recommend you always start a new thread. Posting on a two-year thread doesn't have the same visibility.
// Stephen Blair
