Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Traceback errors
9 REPLIES 9
Message 1 of 10
1062 Views, 9 Replies
Traceback errors
(This is just unlicensed arnold for now) Having issue with Arnold to Houdini Indie. Windows 10. Houdini 16.5.439. Arnold = htoa-3.0.1_r0f08864_houdini-16.5.439_windows
I can't seem to get past this issue after many many hours,Things that are weird are some file paths in that error have m ismatched forward and back slashes.
I wasn't sure how to fix that or why it would do that in the first place. I have redshift, but I'm not going to add path just to keep things simple. Python I added just in case it was sourcing incorrect python version.. doesn't change result of error.
Other issues that may be similar are something to do with the visual studio side of things. tried uninstalling visual studio 2017. reinstalling 2017, uninstalling 2015, installing 2015.
adding DSO error check in env variables = Houdini DSO error will say (127) Couldn't load.
C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-16.5.439/dso/htoa_core.dll.This is probably because this file was intended for use with a different version of houdini (yet the versions match up less I'm crazy.)
#HOUDINI_USE_HFS_PYTHON = 1
# htoa config start
PATH = "$PATH;C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-${HOUDINI_VERSION}/scripts/bin" HOUDINI_PATH = "C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-${HOUDINI_VERSION};&"
# htoa config end
I've also tried hardcoded versions of the path and houdini paths
C:\Users\Max\htoa\htoa-3.0.1_r0f08864_houdini-16.5.439\htoa-3.0.1_r0f08864_houdini-16.5.439 C:\Users\Max\htoa\htoa-3.0.1_r0f08864_houdini-16.5.439\htoa-3.0.1_r0f08864_houdini-16.5.439/scripts/bin
I've tried multiple reinstalls of houdini and arnold as well as multiple versions of each. If anything I'd like a way to reset everything and not have this problem at all lol. I've installed it on a friends computer just fine, so not sure why I'm messing stuff up.
Thanks if anyone knows any solution or ideas. I've had a few people try to help and am very grateful.
few ideas were to check vcredist_x64.exe and install that. which I already had unfortunately so thats the whole visual studio stuff. and check my script error locations and see if they were in read only - they were not and they had full privileges.
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
Stephen.Blair
If htoa_core.dll isn't loaded, HtoA isn't going to work.
I don't get any errors with HtoA 3.0.1 and Houdini 16.5.439, so either you've got the wrong version of htoa_core, or it's a dependency problem. So, try using Depending Walker.
// Stephen Blair
// Arnold Renderer Support
Message 2 of 10
Thank you for helping. I'm unsure of what to do with the errors I have in Dependency Walker or how to troubleshoot. As far as versioning of the htoa_core. Do you mean for example HtoA 3.0.1 for 16.5.439 I've checked this, and I've tried several different htoa versions as well as matching up the versions for 16.5.378 and 16.5.268 etc.
I've uploaded the dw file if that helps.
https://drive.google.com/open?id=1nn_arAYEglrSGLorMdDTj8I9e_BGYGo5
Message 2 of 10
Stephen.Blair
Looks like you're missing the Update for Universal C Runtime
https://support.microsoft.com/en-us/help/2999226/update-for-universal-c-runtime-in-windows
// Stephen Blair
Message 2 of 10
Stephen.Blair
Also, there's an old version of Arnold (ai.dll) in your PATH.
In the screenshot, I also highlighted the missing dependencies that suggest that the Update for Universal C Runtime is missing.
// Stephen Blair
Message 2 of 10
Amazing, thank you, I deleted that now just in case. As well, I'm currently on windows 10, I've been looking around for another download. I even tried running all the windows versions that the link from microsoft has But wouldn't let me since I was on windows 10. I do have in system32.
msvcp140.dll
msvcp140_1.dll
msvcp140_1d.dll
msvcp140d.dll
I've been looking around for another download but not sure if I should just download from the internet and overwrite my current .dll
https://www.sts-tutorial.com/sites/downloadCenter.php?msvcp140
https://www.sts-tutorial.com/sites/downloadCenter.php?vcruntime140
or here
https://www.dll-files.com/vcruntime140.dll.html
Just wanted to check before incase I screw up my computer. Since I couldn't find an official microsoft link for the dlls like what you sent me but for windows 10
Also since I saw VCRuntime I wasn't sure if that's related to visual studio stuff. but I just wanted to add just incase I shouldn't. I have microsoft visual c++ x64 / x86 of years 2017, 2013,2012,2010,2008, and 2005 but not year 2015 as I uninstalled it. Not sure if I should reinstall 2015 if I already have 2017.
Message 2 of 10
Hey, feeling a little in the dark here. Not sure what to do still, now that the time has come to get this to work or not. Your link has nothing to do with Windows 10 OS. Even official downloads claiming Windows 10, when extracted, only have up to Windows 8 OS. This does not work for me. Not sure how to even delete these DLL's to manually install the DLL's them selves as they are currently in use by other windows Operations. I can't seem to find an alternate route or Windows 10 Compatible Universal C Runtime.
Message 8 of 10
Stephen.Blair
If you don't think the missing dependencies are a problem, then run Process Monitor and see what files cannot be found when HtoA is loaded.
// Stephen Blair
Message 9 of 10
I'm not sure, I'm sure they are a problem. I'd like to run Universal C Runtime and update them but I cannot.
Message 10 of 10
Reformatted. I don't think this was going to come up with a solution to this error, too many variables. Thanks for your time Stephen. Thanks, have a good one.
