Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Toon Shader & Contour Filter Type - Issues/Questions
22 REPLIES 22
Message 1 of 23
am_wilkins
813 Views, 22 Replies
I haven't used the Arnold Toon shader very much, I see as part of the requirements one is required to switch to the "Contour" filter type.
I noticed that as soon as I switch then the render result appears transparent which seems incorrect to me, as I can't really work with the shader when it looks like this.
(This is just with a "Standard Surface" applied)
Contour Filter Type:
Box Filter Type:
Edit:
More questions, the docs say:
"To increase the edge_width_scale above 1, you will need to increase the contour_filter_width. However, this will increase render times."
1) How do I adjust this in Houdini, I don't see any way on the "Render Settings" node.
Out the box at a scale of 1, the edges are pencil thin.
Noticed this seems to appear on a "Render Var" but aren't available on the Arnold Render Settings HDA.
Sort of answered my own question, but this is another fix/adjustment needed on the HDA.
2) Where is the "UberNoise" OSL used in the docs that will work in Houdini?
The docs just have a dead link. (circled in red)
thanks,
amwilkins
Houdini Core Version 20.0.653
Arnold Core: 7.3.1.0
HotA: 6.3.1.0
CPU: AMD Ryzen TR 3990x
RAM: 128GB
GPU: NVIDIA RTX 4090
OS: Windows
22 REPLIES 22
Message 21 of 23
am_wilkins
in reply to: Stephen.Blair
Oh wow, not sure why that didn't cross my mind.
Was convinced it would just be pathed to the light at stage level. 😅
It's working now!
Thanks so much! 👍
amwilkins
Message 22 of 23
j16salas
in reply to: am_wilkins
@am_wilkins @Stephen.Blair Thank you both for this thread. This is a wealth of information.
Message 23 of 23
j16salas
Technology Administrators
