Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
There is no Filter setting in the Samples item of the Solaris Render Settings.
6 REPLIES 6
hiromi-y
305 Views, 6 Replies
When I create an Arnold ROP in the OUT context, there is an option called Pixel Filter in the Sampling settings.
By changing this Pixel Filter setting to Contour, I can render the Toon outline.
However, there is no Pixel Filter setting in the Arnold tab of Solaris' Render settingsLOP.
Is there a way to draw Toon outlines in Solaris?
6 REPLIES 6
Stephen.Blair
in reply to: hiromi-y
Filter is on the Arnold tab of a Render Var LOP
// Stephen Blair
// Arnold Renderer Support
hiromi-y
Thank you Stephen-san!!
hiromi-y
I created  a Render Var LOP and changed the filter to Contour.
But I can't got the outline.
I attached the sample scene with a rubber toy .
Would you be able to tell me how to get an outline?
Houdini 19.5.435
HtoA 6.1.4.1
Hiromi
Stephen.Blair
Ah, I didn't see you attached a file (I follow mostly through email). So here's my test scene that has Toon edges on Shaderball.
// Stephen Blair
Stephen.Blair
You have to set up Render Var > Render Product > Render Settings
Then you'll get the Toon shading
// Stephen Blair
hiromi-y
in reply to: Stephen.Blair
Hello Stephen,
I got the ourlines!!
Thank you!
Best Regards,
Hiromi
