Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Strange error adding simple geometry to scene
4 REPLIES 4
stevegkennedy
212 Views, 4 Replies
If I open up a new project and just try to add a sphere (for example) to the scene, I get this error:
Traceback (most recent call last):
  File "C:/Program Files/Arnold/htoa-6.1.3.1_r90d42a5_houdini-19.5.303/scripts/obj/geo.py", line 3, in <module>
    htoa.properties.initArnoldProperties(kwargs['node'])
  File "C:\Program Files/Arnold/htoa-6.1.3.1_r90d42a5_houdini-19.5.303/scripts/python\htoa\properties.py", line 167, in initArnoldProperties
    addArnoldProperties(node)
  File "C:\Program Files/Arnold/htoa-6.1.3.1_r90d42a5_houdini-19.5.303/scripts/python\htoa\properties.py", line 111, in addArnoldProperties
    node.parm('ar_matte').setExpression('ch("vm_matte")')
AttributeError: 'NoneType' object has no attribute 'setExpression'
In addition, all the properties have disappeared from the ROP:
Any ideas what's going on here?
4 REPLIES 4
This kind of thing is almost always an environment problem.
So, check
  • houdini.env, or if you use packages, the json file
  • Help > About Houdini > Show Details
Remove other stuff and make sure HtoA works. Then add back the other stuff.
// Stephen Blair
// Arnold Renderer Support
With an empty environment file, everything works fine. But with just these lines in the .env it's all broken:
HOUDINI_DSO_ERROR = 2
PATH = "$PATH;C:/Program Files/Arnold/htoa-6.1.3.1_r90d42a5_houdini-19.5.303/scripts/bin"
HOUDINI_PATH = "$HOUDINI_PATH;C:/Program Files/Arnold/htoa-6.1.3.1_r90d42a5_houdini-19.5.303;&"
The strangest thing is that everything was working fine until a few hours ago. Now I am suddenly getting this error too: Houdini Console errors
The only thing I've done which might have caused an issue I suppose is that I ran the Redshift installer. Though I am not currently using Redshift, I don't know if it's somehow done something to some files somewhere.
Maybe a full reinstall might be in order?!
HTOA should be at the start of HOUDINI_PATH
Also, I don't know what's in $HOUDINI_PATH. Is & being used twice when HOUDINI_PATH is expanded? That can cause problems too.
// Stephen Blair
Ah OK, yeah I did have some lines for adding Redshift to the env but I removed them, but had left the $HOUDINI_PATH variable like that. Removing that seems to have fixed it, thanks!
