SOP node selection using Operators workflow
sergeyklesov
sergeyklesov
Is it possible to select SOP node using operators workflow?
For example I have a Box and a Sphere inside one Geo node and I want to change visibility settings only for the Sphere, without touching the Box?
In my tests I've succeed only with .Ass or Alembic files and separate Geo nodes.
For some reason selection wildcard doesn't recognize SOP nodes
Thank you
Stephen.Blair
Operators select Arnold nodes. So if you export your Houdini setup to an ASS file, and take a look at that ass file, you'll see what nodes you can select.
// Stephen Blair
// Arnold Renderer Support
