Solaris - Reserved AOV Names
ip101
Observer Observer
106 次查看
0 条回复
1 条消息(共 1 条)
ip101
Observer
Observer
In Solaris I'm trying to render combined diffuse+sss and specular+coat+sheen+transmission aovs, per light group, using an LPE.
I have this working except if I set the aov name to 'diffuse_' + light group name (e.g. 'diffuse_key'), I lose the the sss contribution and it reverts to just the standard diffuse contribution for that light group. If I set the name to anything else I have the desired diffuse+sss contributions but the aov name is wrong and for comp reasons, I would like to keep  it as 'diffuse_'.
Its the same for specular when trying to combine specular+coat+sheen+transmission into 'specular_key'.
This doesn't happen in Sops when using the same LPE's and desired aov names. Is there a way to get it to work in Solaris?
Thanks!
0 个赞
107 次查看
0 条回复
回复 (0)
