Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Solaris Operator Graph
3 REPLIES 3
pauldonsw
105 Views, 3 Replies
Is it possible to include an Arnold operator graph in Solaris? Or is it only possible with the Arnold USD node at the obj level?
Thanks!
3 REPLIES 3
Stephen.Blair
in reply to: pauldonsw
Thanks!
arnold-usd needs to support operators first, if you want to see something in Hydra:
https://github.com/Autodesk/arnold-usd/issues/740
// Stephen Blair
// Arnold Renderer Support
pauldonsw
Hi Stephen thanks for the reply.
After digging around, can you use a primitive node set to type 'ArnoldIncludeGraph' to achieve this? And then pointing s@arnold:filename to the .ass file?
This works for arnold procedurals but can't get this working for includegraph. Maybe a object path selection issue?
Paul
Stephen.Blair
An Arnold procedural is a shape, that's probably why it works for procedurals, but not an operator like IncludeGraph.
// Stephen Blair
