Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Solaris - GeomSubset material assignments not working with kick
4 REPLIES 4
am_wilkins
242 Views, 4 Replies
Good day,
We've run into an issue while using GeomSubset to make material assignments, saving out our scene USD and kicking it.
The material assignment works rendering within Houdini, it also works if we simply sublayer the same USD file we've just exported back into Houdini—however as soon as we kick this USD file the material assignments don't work.
Does anyone have info on rendering with GeomSubset ?
All the best,
Andrew
4 REPLIES 4
Stephen.Blair
in reply to: am_wilkins
Works with the Arnold render delegate in Houdini? Or not even with that?
This usda from our test suite, which uses GeomSubset, works with kick for me.
// Stephen Blair
// Arnold Renderer Support
am_wilkins
in reply to: Stephen.Blair
Hi Stephen,
Yes, it works with the Arnold render delegate in Houdini, but once written out as a USD file and kicked it was no longer working.
This same USD file sublayered back into Houdini again works in the Arnold render delegate.
Just not when Kicked.
I was taking a look at your attached "test_0036" file
It's rendering as a basic sphere for me?
I will try provide more images or file to show the issue.
Stephen.Blair
This is what I get
// Stephen Blair
am_wilkins
Thank you Stephen, in the process of reproducing the issue to send you files—we've determined that the GeomSubset is indeed working.
We must be having some other issue with our asset setup.
However we've run into another issue, where we are unable to get displacement working while kicking the USD.
I'll start a new thread for this.
