I've been trying to setup the "arnold_cryptomatte_aovs" HDA node, but not having success yet.
(using the USD kitchen scene)
Would like to know what I'm doing wrong?
I'm dropping down the "arnold_cryptomatte_aovs" node, using the same material path on the "Render Settings" node and adding "/Render/Vars/arnold_cryptomatte_aovs/*" to the "Render Product" but even though the AOV appear in the AOV list—they render completely black.
In addition to this, if I try to add by other AOV into the mix... when the "arnold_cryptomatte_aovs" node is active, it removes my other AOV from the list.
Here is everything working, as intended.
Try to add all the AOV, because the "arnold_cryptomatte_aovs" is active, the AOV break.
Bypass the "arnold_cryptomatte_aovs" and all the AOV are working again.
Trying both paths to the main AOV and the cryptomatte also doesn't work:
All the best.
Houdini Core Version 19.5.493
HtoA 6.1.4.3
Arnold 7.1.4.3
