Solaris AOV - Arnold cheat sheet?
am_wilkins
Message 1 of 13
am_wilkins
Hey everyone,
While doing research I've noticed that setting up the Arnold AOV inside Solaris is quite a manual setup. (Of course ideal to automate this) Having to set the Data Type, Format and Filter etc. for each one.
Red Shift have this great "cheat sheet" to assist with the setup, but noted that there is nothing for Arnold?
Link: Houdini Solaris AOVs
Does anyone know of a similar documentation for Arnold?
Or more information on these Data Types.
I've only found the "Render Var" docs, but the information isn't nearly as clear:
Houdini Solaris - Render Var
If the Red Shift docs are referenced matching to the Arnold equivalent AOV, would that work?
All the best.
Replies (12)
Message 2 of 13
am_wilkins
PS. For those who perhaps read this post and shared similar annoyance with the approach to AOV.
In the new update from Arnold (HtoA 6.2.1.0), a new Arnold Render Settings node has been created which pretty much solves the above problem of handling AOV.
  • Arnold Render Settings LOP: A new LOP in Solaris allows you to quickly edit Arnold render settings, such as AOVs, cryptomatte, and more. HTOA-1524
Andrew
Message 3 of 13
info
tested today and it's finally easier to create Aovs', I didn't find any solution to render out RGB per Light group. any idea? thanks
Message 4 of 13
Stephen.Blair
You have to set up each light group AOV individually. There's no way to get them all with just RGBA_*
If that is what you are asking?
// Stephen Blair
// Arnold Renderer Support
Message 5 of 13
info
Tried to add new renderVar node with  ‘RGBA_ key’ but doesn’t work.
Message 6 of 13
Stephen.Blair
You have to use the full LPE for the light group, and give the light a Light Group name
// Stephen Blair
Message 7 of 13
am_wilkins
There is an additional problem with this, if you're using the new "Arnold Render Settings" node (and most people would want to do this) then it doesn't seem possible to append any custom render var to that Arnold Render Settings "Render Product"?
ie. placing a new "Render Var" before or after the "Arnold Render Settings" node and adding the custom AOV to the same prim path doesn't appear to work. Unless there is another way?
Ideally, the "Arnold Render Settings" node could be updated to allow custom AOV to be added to it...
Karma Example:
This method looks cool, because you don't have to have a tool or setup support which will automatically generate all the AOV you need based on the LG names—just does it all for you. But even the old "Arnold ROP" method would be great.
All the best,
Andrew
Message 8 of 13
info
hi, working fine on my side !
Message 9 of 13
am_wilkins
Great, that's good news.
Yeah a bit of a work-around? Since you're avoiding the new "Arnold Render Settings" node—but it works which is good!
And at a bigger scale, we'd require some extensive "Render Var" setup for artists. (Why I'm angling for a better out of of box solution from Arnold)
Message 10 of 13
info
 you are right, it seems it doesn't get the Arnold render vars  if you use "Arnold render Settings" That's weird!
Message 11 of 13
am_wilkins
Just bumping this thread to see if there is any progress from Arnold crew on a solution for adding Light Group AOV within the new "Arnold Render Settings" node.
As far as I can see, we'd simply need to be able to change the "Source Type" to "LPE" on a newly created AOV and that should solve the problem?
Ideally however (as mentioned above) if we do have a better solution from Arnold to adding Light Groups based on all the LPE tags on lights in the scene automatically (Skip over anything that doesn't had a tag) that would be awesome!
We shouldn't have to have an artist create all of the AOV manually.
All the best,
amwilkins
Message 12 of 13
Stephen.Blair
Hi
For reference, the ticket for this is HTOA-2205 "Support light group AOVs in the Arnold Render Settings LOP"
// Stephen Blair
Message 13 of 13
am_wilkins
Thank you!
That's great news 👍🏻
