Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Sick - Solaris material assignments not being picked up when assigned to Shape/Mesh
4 REPLIES 4
pauldonsw
123 Views, 4 Replies
Hi
In Solaris - when assigning materials to the Mesh/Shape rather than Xform/Transform, the Sick executable does not pick these up. Husk however does. In the viewport, the shaders are also correctly assigned.
Is this a bug or is there a reason for this? Reading the USD, the assignments are correct so this does appear to be a Sick specific issue.
Be great to know if I'm missing something here.
Hou - 19.5.569
Htoa - 6.2.1.1
Arnold - 7.2.1.1
4 REPLIES 4
Stephen.Blair
in reply to: pauldonsw
Either works for me. Tested with a grid. .grid1 or grid1/mesh_0, both rendered the same with Direct USD Render enabled.
// Stephen Blair
// Arnold Renderer Support
pauldonsw
Thanks Stephen, Direct USD Render might be my issue then. Will test and get back to you. Thanks
Stephen.Blair
sorry, Direct USD Render is how to render with sick from inside Houdini
// Stephen Blair
pauldonsw
in reply to: Stephen.Blair
Ah I see, okay will have a dig, I must be missing something
