Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
running noice on Solaris husk render
3 REPLIES 3
ahmed.hindy
141 Views, 3 Replies
I am using Houdini 19.5.605 -py3.9 with HtoA 6.2.2.0,
I have a simple scene of some sparks rendered with Husk, I output the required AOVs (RGBA_variance) together with (RGBA) and some helpful but not required AOVs like "diffuse_albedo", "N" and "Z".
now I am running noice.exe command both in cmd and in Houdini TOPs  "generic Generator" with -i and -o commands and its giving me "Required metadata not found, check that the image was rendered directly with Arnold.".
can I add these metadata by hand just to get noice working? Solaris is new and documentation is very sparse.
3 REPLIES 3
Stephen.Blair
in reply to: ahmed.hindy
noice is not supported yet by arnold usd.
Like the message says, the noice metadata is not there.
Have you tried the OIDN or Optix denoisers?
// Stephen Blair
// Arnold Renderer Support
ahmed.hindy
in reply to: Stephen.Blair
well I want to denoise a sequence so Noice is the only solution I currently have.
Stephen.Blair
OIDN might be good enough, you should give it a try.
noice is not supported yet with Solaris
// Stephen Blair
