Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Renders erroring out in HtoA with long error message
0 REPLIES 0
Message 1 of 1
mats_nyman
127 Views, 0 Replies
Houdini Version 20.0.506
HtoA Version: 6.2.4.2_r323c0ca_houdini-20.0.506
OS: Windows 11 Pro
I am getting the following error message when I render a scene I have in Arnold:
I have "Abort on Error" disabled. I have a flickering mesh light in the scene, not sure if that is the reason, seeing as I already turned off Abort on Error.
I have no other render engines installed.
I also put attached my Houdini_Info file in this thread.
Command Exit Code: -1073741819
00:00:00 70MB | [hick] Received: AA: 2 2
00:00:00 70MB | [hick] Received: begin
00:00:00 70MB | [hick] Batch mode
00:00:00 70MB | log started Wed Nov 22 13:45:38 2023
00:00:00 70MB | Arnold 7.2.4.1 [1fee86c4] windows x86_64 clang-15.0.7 oiio-2.4.1 osl-1.12.9 vdb-7.1.1 adlsdk-7.4.2.47 clmhub-3.1.1.43 rlm-14.2.5 optix-6.6.0 2023/10/17 03:22:02
00:00:00 70MB | running on DESKTOP-02C4F7R, pid=4520
00:00:00 70MB | 1 x 13th Gen Intel(R) Core(TM) i9-13900K (32 cores, 32 logical) with 130827MB
00:00:00 70MB | NVIDIA driver version 546.01 (Optix 60806)
00:00:00 70MB | GPU 0: NVIDIA GeForce RTX 4090 @ 2535MHz (compute 8.9) with 24563MB (19221MB available) (NVLink:0)
00:00:00 70MB | Windows 10 (version 10.0, build 22621)
00:00:00 70MB | soft limit for open files changed from 512 to 2048
00:00:00 70MB |
00:00:00 70MB | Installing system handler with mask 255
00:00:00 110MB | [metadata] loading metadata file: C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\arnold.mtd
00:00:00 114MB | [color_manager_ocio] default ocio.config found in C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00 114MB | loading plugins from C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\..\plugins ...
00:00:00 114MB | alembic_proc.dll: alembic uses Arnold 7.2.4.1
00:00:00 114MB | [metadata] loading metadata file: C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 114MB | cryptomatte.dll: cryptomatte uses Arnold 7.2.4.1
00:00:00 114MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.2.4.1
00:00:00 114MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.2.4.1
00:00:00 114MB | [metadata] loading metadata file: C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 114MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.2.4.1
00:00:00 114MB | [metadata] loading metadata file: C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 122MB | usd_proc.dll: usd uses Arnold 7.2.4.1
00:00:00 123MB | [metadata] loading metadata file: C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 123MB | loaded 6 plugins from 4 lib(s) in 0:00.07
00:00:00 134MB | [color_manager_ocio] default ocio.config found in C:\Users\cretor\htoa\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\htoa-6.2.4.2_r323c0ca_houdini-20.0.506\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00 126MB | [hick] Start
00:00:00 126MB | [hick] Received: log_verbosity: 3590
00:00:00 126MB | [hick] Received: log_console_enable: 1
00:00:00 126MB | [hick] Received: log_file:
00:00:00 126MB | [hick] Received: log_max_warnings: 5
00:00:00 126MB | [hick] Received: delta_publisher_port: 2324
00:00:00 126MB | [hick] Received: threads: 0
00:00:00 126MB | [hick] Received: assfile: c:\users\cretor\appdata\local\temp\houdini_temp\htoa_cretor\22412_59e87b8a-fadf-4e0f-93df-4269695c794c.ass
00:00:00 132MB | [metadata] loading metadata file: c:\users\cretor\appdata\local\temp\houdini_temp\htoa_cretor\22412_59e87b8a-fadf-4e0f-93df-4269695c794c.ass
00:00:00 133MB | [ass] loading c:\users\cretor\appdata\local\temp\houdini_temp\htoa_cretor\22412_59e87b8a-fadf-4e0f-93df-4269695c794c.ass ...
00:00:00 134MB | [ass] read 408244 bytes, 31 nodes in 0:00.00
00:00:01 212MB WARNING |
/obj/MeshLight: no polymesh linked to mesh_light
00:00:05 961MB WARNING | signal caught: error C0000005 -- access violation
* Arnold 7.2.4.1 [1fee86c4] windows x86_64 clang-15.0.7 oiio-2.4.1 osl-1.12.9 vdb-7.1.1 adlsdk-7.4.2.47 clmhub-3.1.1.43 rlm-14.2.5 optix-6.6.0 2023/10/17 03:22:02
* CRASHED in AiADPSendPayload at 00:00:00, pixel (1599, 608)
* signal caught: error C0000005 -- access violation
* backtrace:
>> 0 0x00007ffde0e3893e [ai ] AiADPSendPayload
* 1 0x00007ffde08c3b7d [ai ] AiTextureHandleAccess
* 2 0x00007ffde0b5eebd [ai ] AiOutputIteratorDestroy
* 3 0x00007ffde098491d [ai ] AiOutputIteratorDestroy
* 4 0x00007ffde0afe921 [ai ] AiOutputIteratorDestroy
* 5 0x00007ffde0b9714c [ai ] AiOutputIteratorDestroy
* 6 0x00007ffde098491d [ai ] AiOutputIteratorDestroy
* 7 0x00007ffde0afe921 [ai ] AiOutputIteratorDestroy
* 8 0x00007ffde0bc90bb [ai ] AiOutputIteratorDestroy
* 9 0x00007ffde098491d [ai ] AiOutputIteratorDestroy
* 10 0x00007ffde0afe921 [ai ] AiOutputIteratorDestroy
* 11 0x00007ffde0b893fc [ai ] AiOutputIteratorDestroy
* 12 0x00007ffde098491d [ai ] AiOutputIteratorDestroy
* 13 0x00007ffde098bf42 [ai ] AiOutputIteratorDestroy
* 14 0x00007ffde08a8cec [ai ]
* 15 0x00007ffde08a1d82 [ai ]
* 16 0x00007ffde0af202f [ai ] AiOutputIteratorDestroy
* 17 0x00007ffde0ae1757 [ai ] AiOutputIteratorDestroy
* 18 0x00007ffde080171a [ai ] Ordinal0
* 19 0x00007ffde10d223f [ai ] AiADPSendPayload
* 20 0x00007ffde10d1e13 [ai ] AiADPSendPayload
* 21 0x00007ffde0e225e4 [ai ] AiADPSendPayload
* 22 0x00007ffde10cdc6e [ai ] AiADPSendPayload
* 23 0x00007ffde1567799 [ai ] AiADPSendPayload
* 24 0x00007ffde156792d [ai ] AiADPSendPayload
* 25 0x00007ffe7ef59363 [ucrtbase] recalloc
* 26 0x00007ffe80e8257d [KERNEL32] BaseThreadInitThunk
* 27 0x00007ffe816caa58 [ntdll ] RtlUserThreadStart
* loaded modules:
* 0x00007ffde02a0000 ai
* 0x00007ffe7ef30000 ucrtbase
* 0x00007ffe80e70000 KERNEL32
* 0x00007ffe81670000 ntdll
* NOTE: Error reporting is disabled. Please consider enabling error reports to assist in debugging.
0 REPLIES 0
Technology Administrators
