Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
render setting not find
1 REPLY 1
Koji_Masatomi
335 Views, 1 Reply
I hope you do not mind my contacting you out of blue.
Let me ask you some questions about using Arnold with Solaris.
1, The setting tab of "render setting" Arnold of the lop node is blank, but
Is it possible to change the rendering settings? (B.png)
Also, is it possible to network render "usdrender"?
2, Arnold Light node can set the color space by setting the environment variable of OCIO, but (C.png)
The "Dome Lihgt" (E.png) used on solaris did not have an OCIO entry. (C.png)
Is it possible to assign OCIO settings to HDRI?
It would be best if "sceneimportLight" can migrate "ArnoldLight" to soris, but if it is not supported, an error will appear.
Here are the versions of houdini and arnold that have tried the above.
houdini FX version 18.0.287
HtoA  5.0.1
Arnold 6.0.1.0
Houdini 18.0.391
HtoA 5.1.1
Arnold 6.0.2.0
A
B
C
Duplicate of previous question, is it resolved?
Tags (1)
Labels (1)
1 REPLY 1
I was just about to ask the same question about Dome Lights.  The color space option is missing...still...two years later.  The work around is to convert your textures before assigning but it's kind of a pain.
Any chance we will see this added to Solaris?
