Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Render issue with arnold houdini, Render view and output render
15 REPLIES 15
Message 1 of 16
2776 Views, 15 Replies
Hi, i have a problem with instances, when i use the render view it gives me a metadata error and i dont know what to do, im using houdini 18.0.348
00:00:00 3541MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: use_procedural_cache (ar_use_procedural_cache)
cannot read metadata "file_delayed_load" of unregistered type "__delayedload"
Tags (1)
Labels (1)
15 REPLIES 15
Message 2 of 16
schwungsau
hard to say, what format is your render procedural: ass file, obj, alembic?
Message 3 of 16
Stephen.Blair
Does this happen with all scenes? And is it just the Render View, or do all renders have the same errors?
Can you post the full Arnold log?
// Stephen Blair
// Arnold Renderer Support
Message 4 of 16
Ben_Leung
Exactly the same issue from H17 to H18!!!!Tries many ways to solve but without result.
Message 5 of 16
The problem is with the ass file
Here is the same ass file rendered in maya without pb, but not in Houdini!
The solution I found is re save again the ass file in houdini,
soldier.zip
soldierEdited.zip
Message 6 of 16
mukai880411
https://www.openvdb.org/documentation/doxygen/changes.html#v7_0_0_changes
maybe arnold's openVDB version is too low.
Version 6.2.0 - September 18, 2019
New features:
  • Added FindActiveValues, which counts the active values in a tree that intersect a given bounding box.
  • Added DelayedLoadMetadata, which stores mask offsets and compression sizes on write to accelerate delayed load reading.
Message 7 of 16
Ben_Leung
00:00:00 367MB | log started Fri Mar 13 14:53:29 2020
00:00:00 367MB | Arnold 6.0.2.0 [f2a1d573] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 14:28:45
00:00:00 367MB | running on GPU-NODE, pid=28120
00:00:00 367MB | 1 x Intel(R) Core(TM) i9-9900X CPU @ 3.50GHz (10 cores, 20 logical) with 130738MB
00:00:00 367MB | NVIDIA driver version 441.66 (Optix 60600)
00:00:00 367MB | GPU 0: GeForce RTX 2080 Ti @ 1650MHz (compute 7.5) with 11264MB (11044MB available) (NVLink:0)
00:00:00 367MB | GPU 1: GeForce RTX 2080 Ti @ 1650MHz (compute 7.5) with 11264MB (11049MB available) (NVLink:0)
00:00:00 367MB | GPU 2: GeForce GTX 1080 Ti @ 1582MHz (compute 6.1) with 11264MB (10285MB available) (NVLink:0)
00:00:00 367MB | Windows 8 Professional (version 6.2, build 9200)
00:00:00 367MB | soft limit for open files raised from 512 to 2048
00:00:00 367MB |
00:00:00 367MB | [htoa_op] Begin registration ...
00:00:00 367MB | loading plugins from C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/plugins ...
00:00:00 367MB | alembic_proc.dll: alembic uses Arnold 6.0.2.0
00:00:00 368MB | cryptomatte.dll: cryptomatte uses Arnold 6.0.2.0
00:00:00 368MB | cryptomatte.dll: cryptomatte_filter uses Arnold 6.0.2.0
00:00:00 368MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 6.0.2.0
00:00:00 368MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 6.0.2.0
00:00:00 371MB | usd_proc.dll: usd uses Arnold 6.0.2.0
00:00:00 371MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 371MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/cameras.mtd
00:00:00 371MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/lights.mtd
00:00:00 371MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/operators.mtd
00:00:00 371MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/options.mtd
00:00:00 371MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/shaders.mtd
00:00:00 373MB | [htoa_op] Loading metadata file: C:/Users/Administrator/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/arnold/metadata/shapes.mtd
00:00:00 373MB | [rop_operators] Registering operators ...
00:00:00 374MB | [rop_operators] operator registration done.
00:00:00 384MB | [vop_shaders] Registering shaders ...
00:00:00 387MB | [vop_shaders] shader registration done.
00:00:00 387MB | [htoa_op] End registration.
00:00:00 387MB |
00:00:00 387MB | releasing resources
00:00:00 384MB | Arnold shutdown
00:00:00 75MB | Arnold 6.0.2.0 [f2a1d573] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 14:28:45
00:00:00 76MB | authorizing with default license managers: rlm, network, user ...
00:00:00 80MB | [rlm] authorized for "arnold 21990101" from server localhost in 0:00.05
00:00:00 80MB | [rlm] expiration date: 31-dec-2099 (29148 days left)
WARNING: Found hotkey for context 'h.pane.gview.state.lop.stagemanager' before the context definition
WARNING: Found hotkey for context 'h.pane.gview.state.sop.sidefx_stroke' before the context definition
00:00:00 832MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type)
00:07:51 872MB WARNING | [htoa.colorspace] Found more than one arnold ROP with ar_color_space_singleton set, using /out/arnold1. Please ensure there is a unique color space ROP.
00:07:51 872MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type)
00:09:37 876MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type)
00:19:15 873MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type)
Message 8 of 16
I have the same problem with my render. did you find any solution ? All worked just not the frame 30 to 41 (white or cropped) for me with the same error "cannont read metadata".
Message 9 of 16
schwungsau
we are still waiting for a htoA bug fix on this one
Message 10 of 16
Stephen.Blair
in reply to: schwungsau
This is an OpenVDB warning (not an errro) and the message is logged by OpenVDB
// Stephen Blair
Message 11 of 16
in reply to: Stephen.Blair
Ok thank you and there is any solution to fix that ? Because when I render, some of frame are white or incomplete. I rendered with Mantra and all worked. Thanks
Message 12 of 16
Stephen.Blair
Arnold does use delayed loading, it just doesn't know about the metadata.
That's unlikely to cause render problems
What else is in a Detailed Arnold log?
// Stephen Blair
Message 13 of 16
schwungsau
thats warning, proberly openVDB3 vesion mismatch... i have same warning in maya and gaffer but arnold renders it correctly.
Message 14 of 16
Just that like 10 Times. 😕
I don’t know why some frame is perfectly working and aime not.
Message 15 of 16
schwungsau
sounds like an Houdini issues, check your bounding boxesd on this frame, maybe there are nan's or incredible bounding box sizes (like 5 billion unit etc..)
Message 16 of 16
ahmed.hindy
same issue with Houdini 18.5
