Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Proper syntax for creating Tx files from an image sequence used as a texture
2 REPLIES 2
slylebeau
505 Views, 2 Replies
Hey guys!
I was trying today to create Tx files out of a Tiff sequence and was unable to find how to do it in the terminal. I've tried ####, %04d, $F4, *.*, *.tiff..... etc.... But it was always returning an error that it needed a specific file name. How to batch process many files at once?
thanks for your time!
sly
Tags (1)
Labels (1)
  • tx
2 REPLIES 2
Stephen.Blair
in reply to: slylebeau
You'll have to loop over the files and call maketx once per file.
So it depends on what you're using: batch file? python? shell script?
// Stephen Blair
// Arnold Renderer Support
for windows and bat use this (you can drag and drop images onto it):
SET PATH=%PATH%;o:\applications\pipeline\launch\repo\houdini_htoa\htoa-1.12.1_r1781_houdini-15.5.523\scripts\bin
@for %%i in (%*) do maketx -v -u --unpremult --oiio --colorconvert sRGB linear %%i --format exr -d half --compression dwaa
