Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Problem Importing Arnold Shaders in Houdini Build 462
3 REPLIES 3
ChanceNorris7638
368 Views, 3 Replies
I'm having an issue importing Arnold Shaders in Houdini 18.5 Build 462 with Arnold build for 462.
I'm exporting Arnold Shaders from Maya and importing into Material Network node in Houdini. This workflow worked fine in previous builds. Here is error message in Houdini
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "C:/Users/chanc/htoa/htoa-5.6.0.0_r370661f_houdini-18.5.462/htoa-5.6.0.0_r370661f_houdini-18.5.462/scripts/python\htoa\material.py", line 267, in importMaterials
materialImport(material_context, filename)
File "C:/Users/chanc/htoa/htoa-5.6.0.0_r370661f_houdini-18.5.462/htoa-5.6.0.0_r370661f_houdini-18.5.462/scripts/python\htoa\material.py", line 243, in materialImport
importer.run()
File "C:/Users/chanc/htoa/htoa-5.6.0.0_r370661f_houdini-18.5.462/htoa-5.6.0.0_r370661f_houdini-18.5.462/scripts/python\htoa\material.py", line 424, in run
surface = self.traverse(material.get('surface'))
File "C:/Users/chanc/htoa/htoa-5.6.0.0_r370661f_houdini-18.5.462/htoa-5.6.0.0_r370661f_houdini-18.5.462/scripts/python\htoa\material.py", line 497, in traverse
pushHouParms(op, vop, '', is_osl)
File "C:/Users/chanc/htoa/htoa-5.6.0.0_r370661f_houdini-18.5.462/htoa-5.6.0.0_r370661f_houdini-18.5.462/scripts/python\htoa\node\node.py", line 741, in pushHouParms
if isMultiBool(node_entry, arnold_name):
NameError: global name 'isMultiBool' is not defined
Tags (1)
Labels (1)
3 REPLIES 3
Hi @Chance
That's a bug in HtoA 5.6.*
The isMultiBool function is missing from scripts\python\htoa\node\node.py
def isMultiBool(node_entry, parm):
    '''Check if a parameter is a toggled array parameter from its metadata
    res = POINTER(c_bool)(c_bool(False))
    if AiMetaDataGetBool(node_entry, parm, 'houdini.toggled', res):
        return res.contents.value
    else:
        return False
// Stephen Blair
// Arnold Renderer Support
Thanks Stephen! Solved!
Thanks for reporting, this will be fixed in the next release, htoa#1662.
Technology Administrators
