Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Pref in houdini
7 REPLIES 7
Message 1 of 8
chris
1795 Views, 7 Replies
Pref in houdini
I'm trying to set up a Pref pass for a simple animated object in houdini/arnold. Im generally a maya user & its as simple as making a texture ref copy of the aniamted object & turning on the pref AOV there, seems not as straight forward in houdini .
any help greatly appreciated
Chris
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
Stephen.Blair
in reply to: chris
Did you see the bottom of this page?
https://docs.arnoldrenderer.com/display/A5AFHUG/Noise
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
there's nothing there
Message 4 of 8
Message 5 of 8
You mean this ;
"The Pref attribute must be of type "Float" (size 3) and sub-type of "Position". In Arnold's terms, it's userdata of type PNT. To add Pref to an object first create a rest node to make the reference pose and then create a Pref attribute."
Adding that with the link would be really helpful
Message 6 of 8
The Pref that this creates has 0, 8, or 16 channels ( depending on the Rest node settings, default creates nothing ), where for example P has x,y & z, this has Pref[0] through Pref [15], and every value is 0.0 except for the first and every 4th channel, which is 1.0. Even if I could figure out how to convert this into a vector or float, everything in the aov would just be solid red.
Message 7 of 8
I should mention that I'm importing/rendering .ass files, non-deforming geo, thanks for any advice.
Message 8 of 8
toby.gainesQTXCX
in reply to: chris
It appears that the Pref value is the *same* as the rest value - ? Unchanged? If that's the case, then all I need to do is get that rendered into rgb, which is pretty straightforward
