Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Override dome light camera contribution
4 REPLIES 4
edelacour
318 Views, 4 Replies
Hey,
Pretty dumb question I'm sure but how can I override a light setting like camera visibility for a rop, like in Maya I'd just right click and override it within a render setup?
Thanks!
4 REPLIES 4
Houdini uses "Takes" which is the drop-down list in the upper right-hand corner of the main window. However most of us just make another dome light, and switch it out in the different rops. It's a bit easier to keep track of that way
Hello, and thanks a lot for the prompt answer! Do you mean you'd use bundle to switch between different light groups?
Nope just 2 different domes for your different rops. You won't be able to use the wildcard '*' in your rops that way, but your scene would have to be extremely simple to use those
I don't use bundles personally, they're just one more thing to keep track of.
Thanks a lot!
