Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
OSL Shader
3 REPLIES 3
sapralexnet
117 Views, 3 Replies
OSL Shader
Hello. I’m following this tutorial for OSL Fractals https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_rendering_ah_Rendering_Volumetric_...
When I try to use mandelbulb_shader in OSL node in Houdini I get “syntax error” on all lines where the code has backslash
 If I create .osl files instead, Arnold in Houdini just doesn’t see(or doesn’t compile) the files which has the mentioned backslash \.
The first simple sphere_shader works as expected in both cases(written in OSL node or as a file)
Would appreciate any help. Thanks
3 REPLIES 3
thiago.ize
in reply to: sapralexnet
It looks like there was some transcription error when we moved this code onto the new documentation website. In fact, I'm seeing this error in other pages as well. I don't have a copy of the original code to compare with but I think you might be able to fix this by removing the backslashes. So \* becomes just * (it's supposed to be a regular multiplication).
In the meantime, we'll work on fixing these issues. Thanks for bringing this to our attention!
sapralexnet
in reply to: thiago.ize
Yeah, I’ve initially tried just removing the backslashes in the mandebulb_shader, however this always result in a crash, so I thought that this is wrong. Will try on the other ones. Thanks for keeping an eye on this.
sapralexnet
Today’s update: I’ve tried deleting the backslashes in .OSL file and it works fine now, so I’ll proceed with this way.
