Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
object properties error when added
2 REPLIES 2
jofish002
147 Views, 2 Replies
Traceback (most recent call last):
File "/Users/josephibrahim/htoa/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/scripts/obj/geo.py", line 3, in <module>
htoa.properties.initArnoldProperties(kwargs['node'])
File "/Users/josephibrahim/htoa/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/scripts/python/htoa/properties.py", line 167, in initArnoldProperties
addArnoldProperties(node)
File "/Users/josephibrahim/htoa/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/htoa-6.2.2.0_rf4b9c5b_houdini-19.5.605/scripts/python/htoa/properties.py", line 111, in addArnoldProperties
node.parm('ar_matte').setExpression('ch("vm_matte")')
AttributeError: 'NoneType' object has no attribute 'setExpression'
Labels (2)
2 REPLIES 2
Stephen.Blair
in reply to: jofish002
This kind of thing is almost always an environment problem.
So, check
  • houdini.env, or if you use packages, the json file
  • Help > About Houdini > Show Details
Remove other stuff and make sure HtoA works. Then add back the other stuff.
// Stephen Blair
// Arnold Renderer Support
jofish002
in reply to: Stephen.Blair
Thank you!
that definitely solved the problem.
I am still using a .env
 But after this I’m moving to packages.
Cheers
Joseph
