Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Multiple uv sets, packed geometry
4 REPLIES 4
zenop
772 Views, 4 Replies
Is it possible to use multiple UV sets in htoa on packed geometry?
Currently I have a secondary uv set named "uv2". If I use "uv2" in the uv set parameter of the image shader it only picks it up if the geometry is unpacked. I would expect the vertex attributes to be carried the same way as the point attributes when the geometry is packed?
How should I be doing this?
Zeno
Tags (2)
Labels (2)
4 REPLIES 4
julian.hodgson
in reply to: zenop
This should work, for example the included file has two uvsets, the geometry is packed, but it's unpacked at render time and uses the uv2 set.
packed_uv.zip
Do you have a different situation?
zenop
in reply to: zenop
Hi Julian,
Looking into this some more. It does work when using your method. However, when I export it through an alembic rop & load it back in, it doesn't pick up the uv2 set. I didn't change any settings in the alembic rop/import.
Any idea why this could be happening?
Zeno
Hi Julian,
Your example does work. I will try and replicate it since it doesn't work on my end where it's read through an abc cache.
Will investigate, thanks for the working example.
Zeno
in reply to: zenop
set Face sets to Save All Groups As Face Sets in rop_alembic/Geometry
julian.hodgson
in reply to: zenop
For the alembic, you need to specify the extra uv set when exporting e.g.
