Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Missing Material Palette
2 REPLIES 2
Ruteger_Handsom
343 Views, 2 Replies
Installed Arnold 5.0.1 for Houdini 18.0.287 but the Arnold Material Palette is missing. I only see Mantra.
Everything else seems to work okay and renders are fine, but all is in grey. The normal Arnold Shelf tabs are there also and seem to function normally. Here is my .env file.
PATH = "$PATH;C:/Users/Joe/htoa/htoa-5.0.1_r5e954ab_houdini-18.0.287/htoa-5.0.1_r5e954ab_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/Joe/htoa/htoa-5.0.1_r5e954ab_houdini-18.0.287/htoa-5.0.1_r5e954ab_houdini-${HOUDINI_VERSION};&"
PXR_PLUGINPATH_NAME = "C:/Users/Joe/htoa/htoa-5.0.1_r5e954ab_houdini-18.0.287/htoa-5.0.1_r5e954ab_houdini-${HOUDINI_VERSION}/hydra"
2 REPLIES 2
in reply to: Ruteger_Handsom
Here you go:
- Put the folder gallery to C:\Users\XXX\Documents\houdini18.0
- put the file Renderers to C:\Users\XXX\htoa\htoa-5.0.1_r5e954ab_houdini-18.0.287\htoa-5.0.1_r5e954ab_houdini-18.0.287
- Check Solid Angle under Houdini Prefernces:(Edit/Preferences/Rendering)
- Choose Arnold from Material Palette
5533-htoa-materialpalette.jpgMaterialPalette.zip
Thank you, that did the trick. All is working now 🙂
