Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Missing Arnold Shaders with htoa-6.1.3.1 py37 Houdini 19.5.303 on Ubuntu 20.04
3 REPLIES 3
mats_nyman
1022 Views, 3 Replies
These are my env file, Houdini variables and the version of Arnold I installed.
For all I can tell everything in Arnold is working except for the shaders which are all missing from both /mat and /shop.
Even the Arnold VOP network is not there, and I have no "Arnold" at the top of the Tab-menu in any of these contexts.
I tried removing all my other plug-ins but nothing seems to fix the issue.
I also checked the license and everything is up.
There is no traceback error when opening or closing Houdini.
However when I try to create an Arnold light I am met with this error:
Same thing happens with the Arnold Volume node in /obj:
Other than that the Arnold menu is showing at the top and I can create Arnold ROPs in /out.
How can I go about fixing this?
Thank you for reading and have a nice day.
EDIT: One more thing; I also switched the ACES and Arnold orders in the .env file but to no avail Im afraid.
3 REPLIES 3
Stephen.Blair
in reply to: mats_nyman
The default Houdini 19.5 install is the Python 3.9 version of Houdini
You have the HtoA for Python 3.7
What Houdini did you install? 3.7 or the default (3.9) ?
// Stephen Blair
// Arnold Renderer Support
mats_nyman
Oh that seems to have fixed it. Didn't think of that!
Thank you so much Stephen
grfGNJCS
Thanks, I had the same problem and was able to fix it!
