Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Material error when using PDG
3 REPLIES 3
alainh3d
318 Views, 3 Replies
test_PDG_files.zipI run into a little problem when using PDG. It's a very simple scene, driven by a CSV file. Basically, a simple box that changes size & materials. I then want a render from 2 different cameras.
I tried it with Mantra & Arnold. No problems with Mantra, but here is the error that Arnold gives:
00:00:02 338MB | log started Tue Nov 23 17:54:33 2021
00:00:02 338MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:02 338MB | running on CORSAIR-II, pid=44480
00:00:02 338MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:02 338MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:02 338MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8235MB available) (NVLink:0)
00:00:02 338MB | Windows 10 (version 10.0, build 19043)
00:00:02 338MB | soft limit for open files changed from 8192 to 2048
00:00:02 338MB |
00:00:02 338MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:02 356MB | [color_manager_ocio] default ocio.config found in C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:02 356MB | loading plugins from C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:02 357MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:02 357MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:02 357MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:02 357MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:02 357MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:02 357MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:02 357MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:02 357MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:02 378MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:02 378MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:02 378MB | loaded 6 plugins from 4 lib(s) in 0:00.09
00:00:02 398MB | [htoa_op] Begin registration ...
00:00:02 401MB | [obj_procedurals] Registering procedurals ...
00:00:02 406MB | [obj_procedurals] procedural registration done.
00:00:02 406MB | [obj_procedurals] Registering procedurals ...
00:00:02 409MB | [obj_procedurals] procedural registration done.
00:00:02 398MB | [rop_operators] Registering operators ...
00:00:02 398MB | [rop_operators] operator registration done.
00:00:02 398MB | [htoa_op] End registration.
00:00:02 398MB |
00:00:02 398MB | releasing resources
00:00:02 380MB | unloading 4 plugins
00:00:02 380MB | closing alembic_proc.dll ...
00:00:02 380MB | closing cryptomatte.dll ...
00:00:02 380MB | closing htoa_mandelbulb_proc.dll ...
00:00:02 380MB | closing usd_proc.dll ...
00:00:02 377MB | unloading plugins done
00:00:02 377MB | Arnold shutdown
00:00:02 374MB | [rop_operators] Registering operators ...
00:00:02 374MB | [rop_operators] operator registration done.
00:00:02 406MB | [vop_shaders] Registering shaders ...
00:00:02 406MB | [vop_shaders] shader registration done.
00:00:02 406MB | [vop_imagers] Registering imagers ...
00:00:02 406MB | [vop_imagers] imager registration done.
[htoa] HTOA environment variable already set to C:/Users/Alain HANNI/htoa/htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3/htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3
00:00:00 442MB | log started Tue Nov 23 17:54:37 2021
00:00:00 442MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 442MB | running on CORSAIR-II, pid=44480
00:00:00 442MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 446MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 446MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8236MB available) (NVLink:0)
00:00:00 446MB | Windows 10 (version 10.0, build 19043)
00:00:00 446MB | soft limit for open files is set at 2048
00:00:00 446MB |
00:00:00 448MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 464MB | [color_manager_ocio] default ocio.config found in C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 464MB | loading plugins from C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 464MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 464MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 464MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 464MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 464MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 485MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 485MB | loaded 6 plugins from 4 lib(s) in 0:00.09
00:00:00 468MB | unloading 4 plugins
00:00:00 468MB | closing alembic_proc.dll ...
00:00:00 468MB | closing cryptomatte.dll ...
00:00:00 468MB | closing htoa_mandelbulb_proc.dll ...
00:00:00 468MB | closing usd_proc.dll ...
00:00:00 465MB | unloading plugins done
00:00:00 465MB | Arnold shutdown
00:00:00 462MB | log started Tue Nov 23 17:54:37 2021
00:00:00 462MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 462MB | running on CORSAIR-II, pid=44480
00:00:00 462MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 465MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 465MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8236MB available) (NVLink:0)
00:00:00 465MB | Windows 10 (version 10.0, build 19043)
00:00:00 465MB | soft limit for open files is set at 2048
00:00:00 465MB |
00:00:00 467MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 483MB | [color_manager_ocio] default ocio.config found in C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 483MB | loading plugins from C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 483MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 483MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 483MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 483MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 483MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 483MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 483MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 483MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 493MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 493MB | [metadata] loading metadata file: C:\Users\Alain HANNI\htoa\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 493MB | loaded 6 plugins from 4 lib(s) in 0:00.09
00:00:05 613MB | unloading 4 plugins
00:00:05 613MB | closing alembic_proc.dll ...
00:00:05 613MB | closing cryptomatte.dll ...
00:00:05 613MB | closing htoa_mandelbulb_proc.dll ...
00:00:05 613MB | closing usd_proc.dll ...
00:00:05 610MB | unloading plugins done
00:00:05 610MB | Arnold shutdown
[17:54:51.140] Running Houdini 19.0.383 with PID 44480
[17:54:51.148] Loading .hip file Z:/HOUDINI/_HoudiniProjects/My_Projects/PDG/test_PDG_arnold.hiplc.
[17:54:51.737] Traceback (most recent call last):
File "C:/Users/ALAINH~1/AppData/Local/Temp/houdini_temp/test_PDG_arnold/pdgtemp/35864/scripts/rop.py", line 1663, in <module>
main()
File "C:/Users/ALAINH~1/AppData/Local/Temp/houdini_temp/test_PDG_arnold/pdgtemp/35864/scripts/rop.py", line 1659, in main
run_job(settings)
File "C:/Users/ALAINH~1/AppData/Local/Temp/houdini_temp/test_PDG_arnold/pdgtemp/35864/scripts/rop.py", line 1418, in run_job
hou.hipFile.load(hip_local, ignore_load_warnings=True)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.383/houdini/python3.7libs\hou.py", line 50477, in load
return _hou.hipFile_load(self, file_name, suppress_save_prompt, ignore_load_warnings)
hou.OperationFailed: The attempted operation failed.
Error loading: Z:/HOUDINI/_HoudiniProjects/My_Projects/PDG/test_PDG_arnold.hiplc
Warning: Bad node type found: arnold::standard_surface in /mat/blue.
Error: Unknown operator on load "standard_surface1.def".
Unknown operator on load "standard_surface1.parm".
Unknown operator on load "standard_surface1.userdata".
Warning: Bad node type found: arnold::standard_surface in /mat/red.
Warning: Bad node type found: arnold::standard_surface in /mat/white.
Unknown operator on load "standard_surface1.userdata".test-pdg-ropfetch-arnold-error.jpg
Tags (1)
Labels (1)
3 REPLIES 3
Stephen.Blair
in reply to: alainh3d
All those errors and warnings are typical of an environment issue. PATH and HOUDINI_PATH are not set correctly for HtoA
// Stephen Blair
// Arnold Renderer Support
alainh3d
Thank you Stephen. I uninstalled htoa (it was in c:\users by default, I'm on win10pro) and reinstalled it in program files. But I still get the same error. It's just when I use PDG that the error happens, otherwise htoa works perfectly fine...
Should I set htoa to start with a json file instead?
This is what my ENV file looks like:
# htoa config start
PATH = "$PATH;C:/Program Files/Arnold/htoa6/htoa-6.0.1.0_rb2fc4a5_houdini-${HOUDINI_VERSION}.py3/scripts/bin"
HOUDINI_PATH = "C:/Program Files/Arnold/htoa6/htoa-6.0.1.0_rb2fc4a5_houdini-${HOUDINI_VERSION}.py3;&"
# htoa config end
OCIO = "C:\Program Files\OpenColorIO_1\config.ocio"
Update...
Well, I finally got to install htoa with a json file...
So I run the test again & his time I get another error... Here it is:
00:00:01 337MB | log started Wed Nov 24 12:04:17 2021
00:00:01 337MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:01 337MB | running on CORSAIR-II, pid=31224
00:00:01 337MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:01 337MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:01 337MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8305MB available) (NVLink:0)
00:00:01 337MB | Windows 10 (version 10.0, build 19043)
00:00:01 337MB | soft limit for open files changed from 8192 to 2048
00:00:01 337MB |
00:00:01 337MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:01 356MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:01 356MB | loading plugins from C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:01 356MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:01 356MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:01 357MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:01 357MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:01 357MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:01 357MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:01 357MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:01 357MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:01 378MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:01 378MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:01 378MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:01 398MB | [htoa_op] Begin registration ...
00:00:01 400MB | [obj_procedurals] Registering procedurals ...
00:00:01 405MB | [obj_procedurals] procedural registration done.
00:00:01 399MB | [rop_operators] Registering operators ...
00:00:01 399MB | [rop_operators] operator registration done.
00:00:01 448MB | [vop_shaders] Registering shaders ...
00:00:01 452MB | [vop_shaders] shader registration done.
00:00:01 452MB | [vop_imagers] Registering imagers ...
00:00:01 453MB | [vop_imagers] imager registration done.
00:00:01 453MB | [htoa_op] End registration.
00:00:01 453MB |
00:00:01 453MB | releasing resources
00:00:01 435MB | unloading 4 plugins
00:00:01 435MB | closing alembic_proc.dll ...
00:00:01 435MB | closing cryptomatte.dll ...
00:00:01 435MB | closing htoa_mandelbulb_proc.dll ...
00:00:01 435MB | closing usd_proc.dll ...
00:00:01 432MB | unloading plugins done
00:00:01 432MB | Arnold shutdown
[htoa] HTOA environment variable already set to C:/Program Files/Arnold/htoa6/htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3
00:00:00 447MB | log started Wed Nov 24 12:04:20 2021
00:00:00 447MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 447MB | running on CORSAIR-II, pid=31224
00:00:00 447MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 450MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 450MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8307MB available) (NVLink:0)
00:00:00 450MB | Windows 10 (version 10.0, build 19043)
00:00:00 450MB | soft limit for open files is set at 2048
00:00:00 450MB |
00:00:00 452MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 468MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 468MB | loading plugins from C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 468MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 469MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 469MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 469MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 469MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 489MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 490MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 472MB | unloading 4 plugins
00:00:00 472MB | closing alembic_proc.dll ...
00:00:00 472MB | closing cryptomatte.dll ...
00:00:00 472MB | closing htoa_mandelbulb_proc.dll ...
00:00:00 472MB | closing usd_proc.dll ...
00:00:00 469MB | unloading plugins done
00:00:00 469MB | Arnold shutdown
00:00:00 466MB | log started Wed Nov 24 12:04:20 2021
00:00:00 466MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 466MB | running on CORSAIR-II, pid=31224
00:00:00 466MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 469MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 469MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8307MB available) (NVLink:0)
00:00:00 469MB | Windows 10 (version 10.0, build 19043)
00:00:00 469MB | soft limit for open files is set at 2048
00:00:00 469MB |
00:00:00 471MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 487MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 487MB | loading plugins from C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 487MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 487MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 487MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 487MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 487MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 487MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 487MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 487MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 497MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 497MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 497MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:05 617MB | unloading 4 plugins
00:00:05 617MB | closing alembic_proc.dll ...
00:00:05 617MB | closing cryptomatte.dll ...
00:00:05 616MB | closing htoa_mandelbulb_proc.dll ...
00:00:05 616MB | closing usd_proc.dll ...
00:00:05 614MB | unloading plugins done
00:00:05 614MB | Arnold shutdown
[12:04:32.655] Running Houdini 19.0.383 with PID 31224
[12:04:32.664] Loading .hip file Z:/HOUDINI/_HoudiniProjects/My_Projects/PDG/test_PDG_arnold.hiplc.
[12:04:33.310] ROP node path '/out/arnold1'
[12:04:33.310] ROP type name: 'arnold'
[12:04:33.310] ROP source path: 'oplib:/Driver/arnold?Driver/arnold'
[12:04:33.310] ROP library path: 'C:/Program Files/Arnold/htoa6/htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3/otls/arnold_rop.otl'
[12:04:33.311] Checking for custom output parms '['vm_picture']' on node '/out/arnold1'
[12:04:33.311] Cooking node using 'hou.Rop.render'
00:00:00 659MB | log started Wed Nov 24 12:04:33 2021
00:00:00 659MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 659MB | running on CORSAIR-II, pid=31224
00:00:00 659MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 663MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 663MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8307MB available) (NVLink:0)
00:00:00 663MB | Windows 10 (version 10.0, build 19043)
00:00:00 663MB | soft limit for open files is set at 2048
00:00:00 663MB |
00:00:00 665MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 684MB | unloading 4 plugins
00:00:00 684MB | closing alembic_proc.dll ...
00:00:00 684MB | closing cryptomatte.dll ...
00:00:00 684MB | closing htoa_mandelbulb_proc.dll ...
00:00:00 684MB | closing usd_proc.dll ...
00:00:00 681MB | unloading plugins done
00:00:00 681MB | Arnold shutdown
00:00:00 678MB | log started Wed Nov 24 12:04:33 2021
00:00:00 678MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 678MB | running on CORSAIR-II, pid=31224
00:00:00 678MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 681MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 681MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8307MB available) (NVLink:0)
00:00:00 681MB | Windows 10 (version 10.0, build 19043)
00:00:00 681MB | soft limit for open files is set at 2048
00:00:00 681MB |
00:00:00 683MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 699MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 699MB | loading plugins from C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 699MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 699MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 699MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 699MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 699MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 699MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 699MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 699MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 709MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 710MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 709MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 90MB | [hick] Received: AA: 3 3
00:00:00 90MB | [hick] Received: begin
00:00:00 90MB | [hick] Batch mode
00:00:00 90MB | log started Wed Nov 24 12:04:34 2021
00:00:00 90MB | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00 90MB | running on CORSAIR-II, pid=39808
00:00:00 90MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130960MB
00:00:00 90MB | NVIDIA driver version 472.12 (Optix 60801)
00:00:00 90MB | GPU 0: NVIDIA GeForce RTX 3080 @ 1710MHz (compute 8.6) with 10240MB (8307MB available) (NVLink:0)
00:00:00 90MB | Windows 10 (version 10.0, build 19043)
00:00:00 90MB | soft limit for open files changed from 512 to 2048
00:00:00 90MB |
00:00:00 90MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\arnold.mtd
00:00:00 106MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 107MB | loading plugins from C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins ...
00:00:00 107MB | alembic_proc.dll: alembic uses Arnold 7.0.0.0
00:00:00 107MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 107MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.0
00:00:00 107MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.0
00:00:00 107MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.0
00:00:00 107MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 107MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.0.0.0
00:00:00 107MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 111MB | usd_proc.dll: usd uses Arnold 7.0.0.0
00:00:00 112MB | [metadata] loading metadata file: C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 112MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 131MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Arnold\htoa6\htoa-6.0.1.0_rb2fc4a5_houdini-19.0.383.py3\scripts\bin\..\ocio\configs\arnold\config.ocio
00:00:00 129MB | [hick] Start
00:00:00 129MB | [hick] Received: log_verbosity: 7942
00:00:00 129MB | [hick] Received: log_console_enable: 1
00:00:00 129MB | [hick] Received: log_file:
00:00:00 129MB | [hick] Received: log_max_warnings: 5
00:00:00 129MB | [hick] Received: delta_publisher_port: 57167
00:00:00 129MB | [hick] Received: threads: 0
00:00:00 129MB | [hick] Received: assfile: c:\users\alainh~1\appdata\local\temp\houdini_temp\htoa_Alain_HANNI\31224_1a869ada-72e1-4eab-8c03-5221e98064c6.ass
00:00:00 134MB | [metadata] loading metadata file: c:\users\alainh~1\appdata\local\temp\houdini_temp\htoa_Alain_HANNI\31224_1a869ada-72e1-4eab-8c03-5221e98064c6.ass
00:00:00 134MB | [ass] loading c:\users\alainh~1\appdata\local\temp\houdini_temp\htoa_Alain_HANNI\31224_1a869ada-72e1-4eab-8c03-5221e98064c6.ass ...
00:00:00 135MB | [ass] read 38755 bytes, 13 nodes in 0:00.00
00:00:11 164MB WARNING | opaque is deprecated: opaque is off for geometry "", but there is no opacity metadata for some of its shaders
00:00:11 180MB ERROR | [aov] output references a non-camera node: /obj/cam_switch
00:00:11 180MB ERROR | [aov] no valid output statements found
00:00:11 180MB WARNING | failed to launch bucket workers: received abort signal
[12:04:46.917] ERROR: The attempted operation failed.
Error: Command Exit Code: -6
00:00:13 719MB | unloading 4 plugins
00:00:13 719MB | closing alembic_proc.dll ...
00:00:13 718MB | closing cryptomatte.dll ...
00:00:13 718MB | closing htoa_mandelbulb_proc.dll ...
00:00:13 718MB | closing usd_proc.dll ...
00:00:13 716MB | unloading plugins done
00:00:13 716MB | Arnold shutdown
Thank you for your help!
Alain
Stephen.Blair
Unfortunately, using a switcher for the camera doesn't work, with or without tops.
// Stephen Blair
