Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Main Crypto_material/asset and object AOV in Solaris rendering black frame. 00, 01 and 02 are fine.
1 REPLY 1
phinnaeusoVVJSU
112 Views, 1 Reply
Hey guys, I'm importing a bunch of stuff into LOPs via the the SOP import node.
These are some KineFX animated geo caches, some flip caches and some hairgen nodes. All created in SOPS/DOPs and imported into lops via geo nodes in contest level
All attributes are deleted apart from P, v, N and uv
Materials are in LOPS via prim groups created in SOPS and imported via the Subset Groups in the Sop import node
Everything renders fine in the RGBA beauty and all AOVs have 90% parity to Beauty when our Flame artist rebuilds them in comp.
BUT
The puzzling problem I'm getting is the main channel for Crypto_material/object/asset are rendering black, all the other channels 00, 01 and 02 are fine.
I've tried every possible solution including a couple posted up by a helpful user here. But to no avail.
Is this a bug? Will it be fixed for the next release??
P
1 REPLY 1
rachid_1
in reply to: phinnaeusoVVJSU
it's completely normal, you have to use other soft like Nuke or fusion to display them correctlly
