Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Kick UV pass for USD input
6 REPLIES 6
apatelKNPJP
241 Views, 6 Replies
Is there a recommended approach to extracting UV pass via Kick for USD input? I'm able to render it within HtoA via primvar "st", but I don't notice a way to achieve that via Kick since it doesn't have an AOV for primvars? Am I missing something here or is there a different approach?
Tags (1)
Labels (4)
6 REPLIES 6
Stephen.Blair
in reply to: apatelKNPJP
kick doesn't create AOVs, they have to already be set up in the exported file.
Best you can do is use kick -is -sm -cm
// Stephen Blair
// Arnold Renderer Support
apatelKNPJP
in reply to: Stephen.Blair
Thank you! Perhaps I should have phrased the question more specifically. I am composing a USD file via Solaris which includes a UV pass. It renders properly with the UV pass (for example below) inside Solaris.
 However, this USD file when rendered through Kick renders all AOVs except the UV pass. This USD file is saved directly via USD ROP in Solaris. My guess is that the USD (see screenshot for the UV pass) contains Hydra or Houdini specific assumptions which Kick isn't able to resolve or perhaps something else is amiss with my workflow?
Stephen.Blair
Can you post an Arnold log?
arnold-usd supports the st primvar for UVs (unless you're using some really old version).
if you check a usda (or resave as ass with kick -i example.usd -resave example.ass), are the UVs there?
// Stephen Blair
apatelKNPJP
Sure, attached is the output log from the kick of the USD. Arnold version in use is 7.1.2.1
I did resave the USD as .ass file with the AOV section as the below screenshot
but it yielded a similar output with an empty AOV with perhaps a bit strangely named "st" channel (instead of UV, as one would expect)Screenshot 2022-09-07 145251.jpg
Stephen.Blair
The AOV is rendered, so it looks like there's no st values being picked up.
Maybe you can send a simple test scene to support at arnoldrenderer dot com? or upload here?
// Stephen Blair
apatelKNPJP
Thanks, I emailed the support with test files and further details. Thank you for your help!
