Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Instancing alembic object with copy to points - broken transforms
2 REPLIES 2
Ali_Veli
628 Views, 2 Replies
When using copy to points sop (pack and instance) with houdini alembic node, changing any render settings parameter breaks the transformations of the copies.
The problem is not exist when i unpack alembic and then instance or using instance object node.
Houdini 18.0.416 - HtoA 5.2.0
Labels (3)
2 REPLIES 2
Ali_Veli
in reply to: Ali_Veli
i forget to mention, this happens while rendering ipr. when you restart ipr everything returns back to normal.
julian.hodgson
Thanks for reporting, this seems to be an IPR refresh problem, and looks like a regression. I've created ticket htoa#1439 to look at this.
