Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Installing Arnold 5.6.0.2 in Houdini 18.5.532 not working ??
6 REPLIES 6
tinggot
585 Views, 6 Replies
hi
I'm using the trial version
When i hit the Arnold render button, it dosen't work with this error (CreateProcess failed for).
Please tell me how to fix it.
Tags (1)
Labels (1)
6 REPLIES 6
Stephen.Blair
in reply to: tinggot
What was logged before that?
And, what is logged by HtoA at startup?
// Stephen Blair
// Arnold Renderer Support
tinggot
in reply to: Stephen.Blair
I'm sorry, I can't understand. I'd like to tell you in detail what you mean. Because I am not very good at English.
Stephen.Blair
In the Houdini Console, there are more messages.
- In the Houdini Console, right click and click Select All
- Press CTRL+C to copy the messages
// Stephen Blair
tinggot
Error when turning on houdini
Error when creating Arnold in ropnet
Error when Render clicked in annold
thank you !!!
because you are using Houdini FX 18.5.532 - Pyhon 3
tinggot
Error running pythonrc.py:
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/python/pythonrc.py", line 11
print '[htoa] HTOA environment variable already set to %s' % os.environ['HTOA']
SyntaxError: Missing parentheses in call to 'print'. Did you mean print('[htoa] HTOA environment variable already set to %s' % os.environ['HTOA'])?
Error when creating Arnold mantra in houdini
Traceback (most recent call last):
File "Driver/arnold, opdef:/Driver/arnold?OnCreated, node /obj/ropnet1/arnold1", line 1, in <module>
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/python\htoa\searchpath.py", line 23, in <module>
if os.environ.has_key('ARNOLD_PROCEDURAL_PATH'):
AttributeError: '_Environ' object has no attribute 'has_key'
Error when Render clicked in Arnold
File "<stdin>", line 2, in expression
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/python\htoa\ocio.py", line 108
print "[OCIO] Invalid color space %s" % cs
SyntaxError: Missing parentheses in call to 'print'. Did you mean print("[OCIO] Invalid color space %s" % cs)?
Error running Python menu script in parameter,
Color Space (/obj/ropnet1/arnold1/ar_exr_color_space):
Color Space (/obj/ropnet1/arnold1/ar_jpeg_color_space):
LDR Color Space (/obj/ropnet1/arnold1/ar_color_family_narrow):
ar_color_space_narrow (/obj/ropnet1/arnold1/ar_color_space_narrow):
Rendering Color Space (/obj/ropnet1/arnold1/ar_color_family_linear):
ar_color_space_linear (/obj/ropnet1/arnold1/ar_color_space_linear):
CreateProcess failed for ''
Error running C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/obj/cam.py:
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/obj/cam.py", line 1, in <module>
import htoa.properties
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/python\htoa\properties.py", line 5, in <module>
import htoa.menus
File "C:/Users/82107/htoa/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/htoa-5.6.0.2_rbd4662c_houdini-18.5.532/scripts/python\htoa\menus.py", line 1, in <module>
import htoa.searchpath
