Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Install problem on El Capitan...
6 REPLIES 6
donotremove23
2700 Views, 6 Replies
I have latest Houdini Indie 16.0.736 and HtoA for it,
after install i don't see any menu or shelf, nothing.
What to do???
Previous version was installed good and visible...
Tags (1)
Labels (1)
6 REPLIES 6
Check your houdini.env
Start houdini from a terminal (eg a Houdini terminal). Then you should see some HtoA log messages (assuming HtoA is found during startup).
// Stephen Blair
// Arnold Renderer Support
This is my .env:
# htoa config start
HOUDINI_PATH = "/Users/Boy/htoa/htoa-2.1.4_rb6da092_houdini-16.0.736/htoa-2.1.4_rb6da092_houdini-${HOUDINI_VERSION};&"
# htoa config end
HOUDINI_NO_SPLASH = 1
HOUDINI_PATH = PATH_TO_YOUR\GameDevelopmentToolset;&
The second HOUDINI_PATH is overwriting the one that adds HtoA to the HOUDINI_PATH
// Stephen Blair
I deleted second path, and now HtoA is starting,
but when i create material or try to render,
it crashing Houdini, why???
Can you post the crash log please?
Where is this crash log file located???
i don't see any log here...
Ok, made simple scene, with box, cam, ar light, ar rop,
This log was created when i hit render button:
00:00:00 462MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 462MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead.
