Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Imoprting Megascan Assets into Arnold/Houdini
1 REPLY 1
eddi_fuhrmann
389 Views, 1 Reply
Hello.
At the moment i am unable to load assets form quixel bridge into houdini/arnold allthoug it says "export successfully". when i choose mantra for import everything works fine and i get the geo/shaders...
get this error in the console:
[htoa] HTOA environment variable already set to C:/Users/eddi_/htoa/htoa-6.0.2.2_r01f7d08_houdini-19.0.531.py3/htoa-6.0.2.2_r01f7d08_houdini-19.0.531.py3
Traceback (most recent call last):
File "C:/Users/eddi_/Documents/Megascans Library/support/plugins/houdini/4.5/MSLiveLink/scripts/python\MSPlugin\MSImporter.py", line 40, in importController
ImportPlant().importAsset(assetData, importOptions, importParams)
File "C:/Users/eddi_/Documents/Megascans Library/support/plugins/houdini/4.5/MSLiveLink/scripts/python\MSPlugin\AssetImporters\ImportPlant.py", line 64, in importAsset
assetMaterial = ImportSurface().importAsset(assetData, importOptions, importParams)
File "C:/Users/eddi_/Documents/Megascans Library/support/plugins/houdini/4.5/MSLiveLink/scripts/python\MSPlugin\AssetImporters\ImportSurface.py", line 37, in importAsset
importedSurface = materialsCreator.createMaterial(importOptions["UI"]["ImportOptions"]["Renderer"], importOptions["UI"]["ImportOptions"]["Material"], assetData, importParams, importOptions)
File "C:/Users/eddi_/Documents/Megascans Library/support/plugins/houdini/4.5/MSLiveLink/scripts/python\MSPlugin\MaterialsSetup\MaterialsCreator.py", line 18, in createMaterial
return self.materialMap[rendererName][materialType](assetData,importParams, importOptions)
File "C:/Users/eddi_/Documents/Megascans Library/support/plugins/houdini/4.5/MSLiveLink/scripts/python\MSPlugin\MaterialsSetup\Arnold.py", line 161, in createMaterial
shaderNode = materialContainer.createNode("arnold::standard_surface")
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/houdini/python3.7libs\houpythonportion\ui.py", line 1081, in decorator
return func(*args, **kwargs)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.531/houdini/python3.7libs\hou.py", line 14148, in createNode
return _hou.Node_createNode(self, node_type_name, node_name, run_init_scripts, load_contents, exact_type_name, force_valid_node_name)
hou.OperationFailed: The attempted operation failed.
Invalid node type name
Is there a way to fix this? thanks and greetings!
Tags (1)
Labels (1)
1 REPLY 1
redshift is working too.
somehow only arnold is causing problems...
