Houdini version: 18.0.597
HtoA version: 5.5.0.0
I have a problem with 2 geometries:
- a stone wall, textured entirely with triplanar and noises
- a book shelf, untextured (just a default Standard Surface)
Both geometries are clean, without any unnecessary attribute or group.
Here's a screenshot of the viewport:
Here's how my wall should look like in the diffuse_albedo and Ambient Occlusion AOVs -please ignore the floating pieces:
When I try to display the book shelf geometry in the render, here's what happens:
Here's what I've tried to do or looked at so far:
- Investigated my wall shader, nothing changed
- Created a new Houdini scene, nothing changed
- Disabled the subdivision and displacement on my wall, nothing changed
- Imported new versions of the geometries, nothing changed
- Tested on both CPU and GPU, nothing changed
- Tried to display any other geometry from my scene, everything works fine until I display the book shelf geometry or the books I have on the book shelves
- A lot more stuff I don't remember (been on it for several hours now)
I checked the log file and nothing wrong or related is in it.
The only workaround I found is to uncheck the "Visible to Shadow Rays" parameter on the book shelf geometry node. With this, I can render both geometries together without having the problem.
But obviously this is not a viable solution, as I don't have the correct shadows on my book shelf geometry.
The shader that is being affected by this issue uses an AmbientOcclusion node. From what I can see after all my tests, is that the Shadow Rays of my book shelf geometry are affecting the AmbientOcclusion of my wall geometry (it basically invert the normals of my geometry but only for the AmbientOcclusion, as the N AOV looks good).
I currently run out of idea on how to fix that.
I can of course make several render layers in order to composite everything together later on, but the render is quite heavy and long on my poor PC so I'd like to avoid that as much as possible.
