Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
[HtoA] Transmission Extra Roughness Parameter locked range
2 REPLIES 2
opdigits
234 Views, 2 Replies
Hello, in the Arnold for Houdini documentation the following is said about "Extra roughness":
Extra Roughness
Adds some additional blurriness of refraction computed with an isotropic microfacet BTDF. The range goes from -1 to 1, where 0 means no roughness. It is computed as
transmission_roughness = specular_roughness + transmission_extra_roughness.
However, in Houdini (18.5.408) with Arnold 6.1.0.1 (HtoA 5.5.0.2) the "Extra Roughness" float parameter is locked between 0-1 and I cannot specify a value below 0.
Could this be a bug?
Labels (4)
2 REPLIES 2
opdigits
in reply to: opdigits
I should mention plugging in a node with a resulting value below 0 works as intended, its just the standard-surface parameter interface.
You can edit shaders.mtd loacted in (HtoA\htoa-5.5.0.2_r1582e12_houdini-18.5.462\arnold\metadatafile) and search for :
[attr transmission_extra_roughness] and change the value from
min FLOAT 0
max FLOAT 1
to
min FLOAT -1
max FLOAT 1
