Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA Set Parameter Operator not work for Material Assignment?
3 REPLIES 3
Slava_91
400 Views, 3 Replies
I use Set Parameter for material assignment but shader cant be finded and render magnetta, if use asset "assign material", material assignment fine and without troubles.
trying path shader = '../matnet1/body/OUT_material' and shader = '../matnet1/body', with relative and absolute path
can't figure out where the error is
Labels (5)
3 REPLIES 3
Stephen.Blair
in reply to: Slava_91
You need to use the shader name that you see in an ASS file.
That won't be ../matnet/body/OUT_material, it will be something like
/obj/matnet1/arnold_materialbuilder1/standard_surface1
// Stephen Blair
// Arnold Renderer Support
Slava_91
in reply to: Stephen.Blair
yes, I try like this but it not work
Stephen.Blair
Please check a Debug-level Arnold log. That will show operator-related messages.
Most likely the selection expression is wrong.
For testing, try a different selection. Like one specific object, or all polymeshes
// Stephen Blair
Technology Administrators
