Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA - Procs frequently disappear in render view
31 REPLIES 31
Message 1 of 32
Andrew_Wilkins1
749 Views, 31 Replies
While doing some render testing (with Arnold Proc rock assets and Operators) in HtoA — I've noticed that the "Arnold Procedural" are frequently disappearing (likely unloading from the cache) in the Render View which a "Render - Regenerate shadow maps and render" doesn't solve.
The only thing that fixes it is re-opening the Render View, which is highly frustrating to do this constantly.
Is this a known issue?
All the best,
Andrew
Houdini: 18.5.596
HtoA: 5.6.3.0
Arnold:
6.2.1.1
Labels (3)
31 REPLIES 31
Message 2 of 32
What are the operators doing to the procedural, and what kind of procedural (alembic? ass? packed?)
// Stephen Blair
// Arnold Renderer Support
Message 3 of 32
  • Procedurals reading an ASS file
  • Operators mainly Set Parameter
Sometimes you're adding assets one-by-one to a Collection and render testing, and then multiple / all the assets would disappear. Only re-opening the render view seemed to correctly refresh the cache.
I suspect this is could be relating to my other post:
https://answers.arnoldrenderer.com/questions/34365/htoa-chaining-set-parameter.html?childToView=3445...
eg. where you're disabling primary visibility on assets which you're adding to a collection one-by-one, it works until you hit a certain asset (likely the asset which is being hit by a ray first and loading in the ASS file?) which then decides to apply to all the procs. Due to "auto-instancing".
side-note:
Would be cool if there was a way to have a Set Parameter or a toggle on it that doesn't just modify the ASS contents at render time—which doesn't seem to play well with auto-instancing.
ie. it just modifies the actual parameter in the scene. Cause then I would assume it would work with auto-instancing (ie. like you would change the parameters manually and that works with auto-instancing)
Andrew
Message 4 of 32
Sounds like an issue with the IPR updates in HtoA.
In the case where all the procedurals load the same ass file...
  • As you set primary visibility one-by-one, you're setting it on specific instances, so it shouldn't hide them all
  • The cached, original object is the first one that is loaded
Procedurals are loaded before any rays are cast, during scene initialization.
Set parameter modifies the Arnold nodes and parameters in RAM.
// Stephen Blair
Message 5 of 32
Is it reproduce-able on your side?
Thanks yeah, the behavior you mentioned it what I'm expecting
Here's an example of disabling prim vis on one asset. Works until I re-enable auto-instancing.
  • Proc rocks, same ASS file.
  • Set_Rock_A_Proc_11 is in the fore-ground
Everything is working as I've intended but "auto-instancing" is disabled on that FG rock.
Turn on "auto-instancing" the rock disappears
(As I assume everything is now being "prim vis disabled" but I haven't done this with the operators)
Collections & Set Parameter nodes
I've had the same thing happen with "Set Parameter - Matte" & "Disable Operator" nodes.
Sometimes they apply to everything and sometimes they don't.
This issue is making it quite difficult to build a stable lighting workflow, as common lighting practices such as: render pass specific "matte, phantom and pruning" for example, are behaving very unpredictably.
Andrew
Message 6 of 32
Nope, I haven't had any problems yet. I set up a scene using the same names for the procedural nodes and the same collections.
Note that your collections are also grabbing the objects loaded by the procedural node. It's enough just to hide the procedural node, so you could do something like this:
*.(@node=='procedural') and #set and not #fg_rock
// Stephen Blair
Message 7 of 32
Interesting!
Yeah I've tried a lot of options, haha
"objects loaded by the procedural node"
Which objects are those? The nodes within "arnold_procedural_viewport1"?
Or the name of the "rock_asset_v001.ass" ?
Ok so using:
With "auto-instancing" re-enabled on all the procedural nodes
Working a lot better! The fore-ground rock is visible while the rest are correctly prim vis disabled.
But somehow the ground geometry has decided to re-appear...
Excuse the change in lighting 😉
Message 8 of 32
The objects in the ass file.
// Stephen Blair
Message 9 of 32
The ground is a polygon mesh?
With "*.(@node=='procedural') and" in the selection, the polymesh isn't selected and so isn't hidden.
// Stephen Blair
Message 10 of 32
And is the ground part of #set ?
// Stephen Blair
Message 11 of 32
am_wilkins
in reply to: Stephen.Blair
Hey, still me—seems I may have lost all of my previous account with the autodesk shenanigans. Pretty sad. I'm now a "reputation 1" noob. ;]
Yeah, so the ground is a polygon mesh and part of the #set collection, so in theory I would assume it should still disable "prim vis" on it.
Message 12 of 32
Stephen.Blair
in reply to: am_wilkins
Ok, I'll test with that setup, but it's still only 6:30 am here...
I'll check your user account and see if there's anything I can do.
// Stephen Blair
Message 13 of 32
am_wilkins
Oh, why are you awake :hot_beverage:
Thanks 🙂
I've also tried a collection with * for sel and called "all" but that also fails.
Message 14 of 32
am_wilkins
Right...
from the .ass, the original rock
polymesh
 name /obj/Set_Rock_A_0/polygons
 matrix
Message 15 of 32
For the original issue: objects disappearing and auto-instancing
That's because the collection selection was getting the polymesh shapes and the procedural node that loads those shapes. So with auto-instancing, we were instancing hidden shapes.
The solution is to either do something with *.(@node=='procedural'), or add "/procedural" to the #fg_rock selection string (eg *Set_Rock_A_Proc_1[346]/procedural instead of *Set_Rock_A_Proc_1[346]* )
// Stephen Blair
Message 16 of 32
Stephen.Blair
It looks like andrew.wilkins@triggerfish.co.za does not have an Autodesk account, not any more (it must have had an account before, since you were able to log on to Arnold Answers with it).
// Stephen Blair
Message 17 of 32
I think adding "/procedural" to fg_rocks should work (better than using *.(@node=='procedural')
// Stephen Blair
Message 18 of 32
am_wilkins
Are we trying to get to the actual "procedural_file" ?
/obj/Set_TestA/Set_Rock_A_Proc_11/arnold_procedural_viewport1/procedural_file/*
Not exactly sure, so tried a few things on the #cc_fg_rock collection—such as:
*Set_Rock_A_Proc_11/arnold_procedural_viewport1/procedural_file/*
*Set_Rock_A_Proc_11/*procedural*/*procedural*
etc.
None of these seem to work
Message 19 of 32
Stephen.Blair
For an Arnold Procedural node in a Houdini scene, HtoA creates a node with a name like /obj/Set_Rock_A_Proc_06/procedural
So a selection like *Set_Rock_A_Proc_1[06]/procedural matches Set_Rock_A_Proc_10/procedural and Set_Rock_A_Proc_16/procedural
In a debug-verbosity log, we'd see this:
00:00:31   256MB         |  [operators] cook op: '/out/set_parameter1' | node: '/obj/Set_Rock_A_Proc_10/procedural'
00:00:31   257MB         |  [operators] cook op: '/out/set_parameter1' | node: '/obj/Set_Rock_A_Proc_16/procedural'
// Stephen Blair
Message 20 of 32
am_wilkins
Hmmm, thanks. Yeah I'm not having much luck
As a selection expression on the #fg_rock collection
*Set_Rock_A_Proc_11*/*procedural*
—this works if I disable "auto-instancing" but nothing appears in the render with "auto-instancing" enabled.
Tried some square brackets, haven't manged to get anything working using this approach
