Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HTOA material node
3 REPLIES 3
jerk001
752 Views, 3 Replies
HTOA material node
Hi guys, is it possible to use the material node inside houdini to assign separate materials to a group of objects. I'm getting a error if i assign a second shader to a bunch of selected objects in a group
Tags (1)
Labels (1)
3 REPLIES 3
frederic.servant
in reply to: jerk001
Yes it's supported, can you post small scene reproducing your issue?
jerk001
materialerror.zipjust adding objects in the group parameter.
julian.hodgson
After adding a light in the scene and some colors to your shader, you can see the assigment is working with your approach: lightroom.zip
