Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA inconsistent render times
3 REPLIES 3
Erik_Lundborg
267 Views, 3 Replies
I'm rendering with HtoA on deadline right now and am having problems with the same rendernodes having different rendertimes. Rendertime right now seems to differ from about 5-10 minutes on a frame to 2-2,5 hours. The frames look completely similar and the only reason i've found seems to be a something called InitializeNodes in the deadline log. Does anyone know what Arnolds InitializeNodes does and where or how i can fix it?
Logs here
https://we.tl/t-dXLJwTAI5U
Labels (3)
3 REPLIES 3
thiago.ize
in reply to: Erik_Lundborg
It's possible this has been fixed in a newer version of Arnold. For instance, Arnold 5.3.1.1 has the following fix:
"Node initialization does not scale when there are procedurals that create many nodes".
I would suggest upgrading to at least this version and if it's still slow, try the very latest.
Thank you for replying! I will try to get an update but could be hard in the middle of a project. It just seems so strange that the same rendernode will differ 2 hours in rendertime between 2 frames that have nothing added or taken away.
thiago.ize
You could also try disabling options.parallel_node_init until you upgrade to a newer arnold. That of course can make that stage slower since it's just using a single CPU core, but compared to the huge slowdown you're sometimes getting, you'll probably still be much faster.
