Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA GPU material override
4 REPLIES 4
miro.digital
189 Views, 4 Replies
Hey Team,
as the title says, material override not working using GPU, could you check to confirm?
H18.5.499 / HtoA 5.6.0.2 / Win10
Chris.
Tags (2)
Labels (2)
4 REPLIES 4
Material overrides how? With operators?
// Stephen Blair
// Arnold Renderer Support
Basic method, Render-Shader Override
I don't use Houdini except for support cases. Do you mean this:
https://www.sidefx.com/docs/houdini/shade/overrides.html#overriding-material-parameters-on-primitive...
// Stephen Blair
Actually you'll find it under the Arnold ROP node, attached screenshot.
https://docs.arnoldrenderer.com/display/A5AFHUG/Main (Shader Override)
