Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Htoa Alembic procedural and Displacement issue
3 REPLIES 3
Slava_91
512 Views, 3 Replies
When using Alembic procedural, displacement not working until you not use unpack ... Attributes ,shaders, sub-d on rendering and etc will work but displacement does not affect until it is unpacked. So there must be or this a bug?
Labels (4)
3 REPLIES 3
julian.hodgson
in reply to: Slava_91
Can you make sure you are using Htoa 3.0.2 or higher? It should be working, please see the displacement.zip test scene for an example.
There's an issue with displacement scale and alembic pimitives which is being investigated currently: https://trac.solidangle.com/htoa/ticket/1049.
Cheers,
Julian
Slava_91
in reply to: julian.hodgson
Hi Julian! Thank for reply,I use 3.0.0.0, new version not used yet.
I will try, thanks for sample!
Slava_91
Yes it work on 3.0.3, thanks again
