HtoA 6.3.5: USD improvements, faster volume intersection, faster baking, Arnold cameras in Solaris, and Cryptomatte on GPU.
Installation
Download Arnold for Houdini from your Autodesk Account. See Download Arnold for more information about downloading HtoA from your Autodesk Account.
Follow these installation instructions
Enhancements
- Arnold camera types now supported in Solaris (HTOA-1749):
- Arnold Render Settings Improvements:
- Camera resolution is now set via an expression automatically, driven by the stage camera. (HTOA-2772)
- The output picture parameter now has a file browser button. (HTOA-2759)
- Added stats and profiling options. (HTOA-1967)
- Classic HtoA Render View Status: Current render status (such as GPU scene updates) are displayed during IPR. (HTOA-1393)
- Selecting the Arnold delegate in the USD Render LOP automatically sets the render complexity to low (HTOA-2733)
- Improved OpenPBR UI (HTOA-2730)
- Render error code in Husk : When a batch render errors out or is aborted, husk now exits with error code, (for Houdini 20.5 and up) (usd#1174)
- Optimized Cryptomatte and GPU support: Arnold now has an internal implementation of Cryptomatte that adds support for GPUs and improves performance on CPU. Cryptomatte now consumes less memory for samples, making it easier to use higher AA settings, progressive rendering, and adaptive rendering (when properly used with FIS). In a simple scene rendered at 640x480 resolution with three cryptomattes the below table shows improvements in peak memory. (ARNOLD-11042)
| CPU | 7.3.4.1 | 7.3.5.0 |
| fixed-AA | 1346MB | 442MB |
| progressive | 3433MB | 532MB |
| adaptive | 8584MB | 441MB |
| GPU | 7.3.4.1 | 7.3.5.0 |
| fixed-AA | - | 799MB |
| adaptive | - | 810MB |
- Corrected clamping of OpenPBR metallic lobe: The OpenPBR metallic lobe Fresnel previously exhibited energy gain when the
specular_weightparameter was increased above 1. This has been corrected so that the Fresnel conserves energy in this case, saturating to a mirror reflection in the limit of highspecular_weight.
Improved instancing in the alembic procedural: Instanced geometries are now better handled in Alembic. This fixes the known issues with
make_instance, which is now enabled by default. (ARNOLD-15209, ARNOLD-8364, ARNOLD-8924, ARNOLD-7818) -
Faster OpenVDB volume intersection: Intersecting OpenVDB volumes are optimized for many-cores. Scenes where volume::intersection is a sizable component of render time can see large speedups. One scene where it accounted for 73% of render time on a 128-core machine saw the volume::intersection time drop to 16% of total time, for an overall 3x speedup in render time. (ARNOLD-15448)
Faster uv_camera baking: The
uv_camera.grid_sizedefault is now 0 instead of 16, where 0 specifies that the grid_size is automatically chosen. Using the new default, baking a sphere with 800k triangles is now 6.5x faster than the previous default. (ARNOLD-15441) -
Add more options settings to image metadata: Images with metadata, such as EXR files, now include
arnold/AA_samples_max,arnold/AA_adaptive_threshold,arnold/fis_filter, andarnold/fis_filter_widthmetadata. (ARNOLD-15521) -
[GPU] Support element linking of array parameters in ramp shaders: Arnold GPU now supports the linking of individual ramp parameter components for the
position,value,color, andinterpolationparameters. (ARNOLD-7120) -
OSL version 1.13.3.0: OSL has been upgraded to version 1.13.3.0. See OSL release notes for details. (ARNOLD-15319)
MaterialX OSL closure support: the OSL closures defined by MaterialX (v1.38) for definition of layered physical materials have been ported to Arnold. For example, all the closures needed to implement the OpenPBR are now available in OSL. See OSL Shaders for more information
Limit node update recursion: Previously, node updates were propagated up the parent chain for all node types. We now do this for shape nodes only. This can improve node update time. (ARNOLD-15492)
Avoid unnecessary node updates: Resetting a node parameter to the current value will no longer cause a node update. (ARNOLD-15402)
Per-parameter update dependencies: Previously, a node update dependency caused a node to be updated whenever the dependency node was modified. We now define these dependencies based on parameters, so the node update is triggered only when one of the specified parameters on the dependency node was modified. (ARNOLD-15483)
Incompatible Changes
- Missing dependencies: Custom nodes must declare all dependencies. Now that Arnold uses per-parameter dependencies, any missing dependencies will result in invalid data that may cause crashes or hangs. Also, shaders that depend on render camera values must declare a dependency on
options.cameraso that the shader is updated when a new camera is set. (ARNOLD-15483)
Bug Fixes
- HTOA-2520 - Setting
@Pon packed alembic primitives no longer breaks shader assignment - HTOA-2686 - Differing abcframe intrinsic on single alembic not working
- HTOA-2766 - Fixed the Dome Light LOP's 'AOV Light Group' menu, it now queries the incoming stage lights
- HTOA-2761 - Arnold Edit Material now supports custom shader types with camel case names
- HTOA-2772 - Fixed expression errors on the camera_projection vop when loading a scene
- HTOA-2771 - Menu metadata now works for integer parms
- HTOA-2743 - Setting an instancer material now correctly sets instance_shader (classic HtoA)
- ARNOLD-11891 - Random crashes when using the Maya hypershade
- ARNOLD-15542 - Crash when modifying light group array on a mesh with instances
- ARNOLD-15478 - [GPU] Hangs and crashes with uv_camera
- ARNOLD-13968 - Add execute permission to ADPClientService on Linux
- ARNOLD-15454 - Support overriding a user property on an instance if defined already on parent
- ARNOLD-11794 - Vector type shaders render black when assigned to a shape
USD Enhancements
Hydra mode in the usd procedural: A new parameter
hydracan be used to render the USD data through a Hydra framework. This supports interactive updates, and can be used to reproduce the same behaviour as a Hydra render delegate (usd#2109 usd#2107 usd#2019 usd#2017 usd#2003) -
transform_keys primvar: When the primvar
arnold:transform_keysis set, it controls the number of time samples used for the matrices of Arnold nodes (usd#2111)
Arnold Cameras in Hydra: Arnold cameras (vr, cylindrical, spherical, uv, fisheye) are now supported in Hydra. You create the Arnold cameras as USD built-in cameras, with a string primvar
arnold:camerathat specifies the Arnold camera type. (usd#1738 usd#2082) -
Improved USD export that better supports Hydra: USD exports now support Hydra, so that scenes from Maya or 3ds Max now render as expected in Houdini Solaris.
- usd#2000 - Write light filters through node graphs so they can be rendered in Hydra
- usd#1965 - Write color manager attributes in the RenderSettings primitive
- usd#2008 - Write spot and photometric lights as UsdLux schemas
- usd#2030 - Write background and atmosphere shaders under a node graph for hydra support
- usd#2031 - Write AOV shaders under a node graph for hydra support
- usd#2025 - Write imagers through node graphs for hydra support
- usd#1987 - Author familyName and familyType in GeomSubsets written as USD
- usd#2080 - Author animated shader attributes in a way that they can render in hydra
- usd#2047 - Shaders exports should be bound to a material
Fixed mismatches between USD and Hydra renders: Several changes were done, either on the procedural or the render delegate, in order to have a consistent behaviour in both code paths.
- usd#1974 - Delegate should only create default shaders when needed
- usd#1959 - Improve translation of normals and primvars in hydra
- usd#1946 - Support color space in materialx for hydra
- usd#2042 - Follow hydra normals skinning behavior in the procedural
- usd#2055 - Support animated curves orientations in hydra
- usd#2053 - Visibility and sidedness attributes not supported in Arnold native hydra prims
- usd#2061 - Support arnold light groups in Hydra
- usd#2086 - Compute FOV in the procedural and hydra in a similar manner
- usd#2057 - Add ginstance support in hydra and fix a data race issue
- usd#2067 - Do not author useless "normals" user data in meshes/curves through the procedural
- usd#2010 - Support TreatAsPoint in spot lights
- usd#1979 - Support treatAsPoint in Hydra photometric lights
UsdPlane support: UsdPlane primitives were previously ignored, and are now rendered in Arnold. (usd#2058)
Improved support for ArnoldProceduralCustom primitives: ArnoldProceduralCustom primitives are now supported like other geometric primitives, including instancing and visibility settings. (usd#2064)
Profiling / Stats: Render settings can now specify filenames to output arnold profiling or stats files (usd#1118)
USD Bug Fixes
- usd#1982 - Fix subdivision when primvars are set in parent primitives
- usd#1997 - Apply correct amount of transform keys when xformOp is set on parent prims
- usd#1972 - Ensure subdivision is disabled when subdiv iterations is equal to 0 in Hydra
- usd#2015 - Support hydra points with empty widths
- usd#2084 - Imagers should be applied to all drivers
- usd#2105 - Ensure the Arnold scene isn't modified after a Hydra batch render started
- usd#1961 - Random curves width in Hydra when radius primvars are authored
- usd#1977 - AOV shaders not set properly in hydra mode of the scene format
- usd#1984 - Cylinder lights not taking normalization into account through USD
- usd#1994 - Fixed hydra errors with varying topologies, and incorrect velocities in first renders
- usd#1992 - Support hydra skinned positions with more than 3 keys
- usd#2027 - Fix faceVarying normals interpolation in the procedural when the mesh is left handed
- usd#1837 - Fix motion blur of instanced skinned geometry with animated parent matrix
- usd#2037 - Improve instances and objects motion blur coherence
- usd#2078 - Ensure the hydra render callback is always invoked
- usd#2094 - Support material interactive updates in the procedural
- usd#2092 - Fix interactive update issue when prims visibility is tweaked in the procedural
- usd#2102 - Remove hydra warning subdiv_iterations: use type BYTE, not INT
// Stephen Blair
// Arnold Renderer Support
