Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
htoa-5.0.0: Unable to load .\htoa_geo.dll - Arnold does not Show Up in Houdini
9 REPLIES 9
Message 1 of 10
paranoidx
780 Views, 9 Replies
Hi, after install htoa-5.0.0_rcd870fd_houdini-17.5.425, Arnold does not show up in Houdini 17.5.425
It's showing this message (in License Diagnostics):
00:00:00 79MB | [kick] command: C:\Users\thor\htoa\htoa-5.0.0_rcd870fd_houdini-17.5.425\htoa-5.0.0_rcd870fd_houdini-17.5.425\scripts\bin\kick -nostdin -v 1 -i Nul
00:00:00 79MB | loading plugins from . ...
00:00:00 80MB WARNING | unable to load dynamic library .\htoa_geo.dll: The specified module could not be found.
There is no Arnold in Houdini for now. How can I proceed to use Arnold, please assist.
How can I fix this. Here is my Houdini.env
# htoa config start
PATH = "$PATH;C:/Users/thor/htoa/htoa-5.0.0_rcd870fd_houdini-17.5.425/htoa-5.0.0_rcd870fd_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/thor/htoa/htoa-5.0.0_rcd870fd_houdini-17.5.425/htoa-5.0.0_rcd870fd_houdini-${HOUDINI_VERSION};&"
PXR_PLUGINPATH_NAME = "C:/Users/thor/htoa/htoa-5.0.0_rcd870fd_houdini-17.5.425/htoa-5.0.0_rcd870fd_houdini-${HOUDINI_VERSION}/hydra"
# htoa config end
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
Stephen.Blair
in reply to: paranoidx
htoa_geo.dll depends mostly on Houdini DLLs
Can you get a Process Monitor log ? That will probably show us what is wrong with your system.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
paranoidx
Weird,
I replied this message but now return and found it empty.
Here is PML file:
https://drive.google.com/open?id=18fayitvKtnPMotFhDiDjfq-vowP-eHZu
Here is from License Diagnostic
https://drive.google.com/open?id=1gJ2UQ2KMYorHTeMHj8lV1g9l5iC0g_X7
Thank you,
Message 4 of 10
Stephen.Blair
How do you start Houdini?
It looks like the current directory is the HtoA scripts/bin folder. As if you did this:
cd C:\Users\thor\htoa\htoa-5.0.0_rcd870fd_houdini-17.5.425\htoa-5.0.0_rcd870fd_houdini-17.5.425\scripts\bin
houdinifx
// Stephen Blair
Message 5 of 10
paranoidx
I don't quite get your question
Here is part to Houdini:
"C:\Program Files\Side Effects Software\Houdini 17.5.425\bin\houdinifx.exe"
Here is part to Arnold:
About the part, "How to start Houdini ?"
I.... click the icon. 😄
Message 6 of 10
Stephen.Blair
Open the Houdini Command Line tools and start houdinifx from there.
What is output to the Houdini Console?
// Stephen Blair
Message 7 of 10
paranoidx
it starts fine, not thing come out to console
It would be great to have this issue soon cure. My trial expire is running out
Message 8 of 10
You do have others Houdini.env file somewhere, like json file in you packages folder! I can see Redshift in your snapshot.
Try this:
Make a backup for your Houdini Pref folder
Start new one with only houdini.env for arnold, it should work!
Message 9 of 10
paranoidx
Thank you
rachid Hadj Abderrahmane, it works now 🙂 save me a tons of time, right of the point. I remove RS setup in Houdini.env
Message 10 of 10
you are welcome
