Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HTOA 19.5.716 not loading
3 REPLIES 3
ChanceNorris7638
205 Views, 3 Replies
I'm having an issue with Houdini 19.5.716 not loading Arnold 19.5.716 "htoa-6.2.3.2_r6e449ce_houdini-19.5.716_windows"  Not sure what I'm missing here ....
Env
# htoa config start
PATH = "$PATH;C:/Users/chanc/htoa/htoa-6.2.3.2_r6e449ce_houdini-19.5.716/htoa-6.2.3.2_r6e449ce_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/chanc/htoa/htoa-6.2.3.2_r6e449ce_houdini-19.5.716/htoa-6.2.3.2_r6e449ce_houdini-${HOUDINI_VERSION};&"
# htoa config end
3 REPLIES 3
Houdini FX Version 19.5.716
Operating System: Microsoft Windows 11 Pro for Workstations x64
Number of Cores: 96
Physical Memory: 190.70 GB
Number of Screens: 2
Screen 0: 3840 x 2160 at 0,0
Work Area 0: 3840 x 2100 at 0,0
Screen 0 DPI: 139.9
Screen 1: 3840 x 2160 at 3840,0
Work Area 1: 3840 x 2100 at 3840,0
Screen 1 DPI: 139.9
Build platform: windows-x86_64-cl19.29
Python Version: 3.9
Qt Version: 5.15.2
USD Version: 22.05
USD git URL: https://github.com/sideeffects/USD.git
USD git Revision: d97bc387c46f32862f5181776a2b1185f0595b8b
UI Scale: 1.250
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: NVIDIA RTX A5000/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 536.96
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
24564 MB
536.96.0.0
Supported Extensions not in OpenGL 3.3 (Version):
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_bindless_texture
GL_ARB_buffer_storage (4.4)
GL_ARB_clear_buffer (4.3)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_copy_texture (4.3)
GL_ARB_debug_output
GL_ARB_draw_indirect (4.0)
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_multi_bind (4.4)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_shader_atomic_counters (4.2)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_shading_language_packing (4.2)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_texture_buffer_range (4.3)
GL_ARB_texture_cube_map_array (4.0)
GL_ARB_texture_filter_anisotropic (4.6)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_KHR_debug (4.3)
GL_NVX_gpu_memory_info
GL_NV_depth_buffer_float
GL_NV_gpu_shader5
WGL_EXT_swap_control
Unsupported OpenGL Extensions used by Houdini:
GL_ATI_meminfo
OpenGL Limits:
ELEMENTS_VERTICES 1048576
ELEMENTS_INDICES 1048576
VERTEX_UNITS 32
TESS_CONTROL_TEXTURE_IMAGE_UNITS 32
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32
GEOMETRY_UNITS 32
FRAGMENT_IMAGE_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 32768
3D_TEXTURE_SIZE 16384
CUBE_MAP_TEXTURE_SIZE 32768
RECTANGLE_TEXTURE_SIZE 32768
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 64
MAX_DEPTH_TEXTURE_SAMPLES 64
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 32768x32768
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 2048
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024
GEOMETRY_OUTPUT_VERTICES 1024
UNIFORM_BLOCKS 84
UNIFORM_BLOCK_SIZE 65536
UNIFORM_BUFFER_BINDINGS 84
COMBINED_VERT_UNIFORM_BLOCKS 14
COMBINED_VERT_UNIFORM_COMPS 233472
TESS_CONTROL_UNIFORM_BLOCKS 14
TESS_CONTROL_UNIFORM_COMPONENTS 2048
TESS_EVALUATION_UNIFORM_BLOCKS 14
TESS_EVALUATION_UNIFORM_COMPONENTS 2048
COMBINED_GEO_UNIFORM_BLOCKS 14
COMBINED_GEO_UNIFORM_COMPS 231424
COMBINED_FRAG_UNIFORM_BLOCKS 14
COMBINED_FRAG_UNIFORM_COMPS 233472
MAX_FRAGMENT_STORAGE_BLOCKS 16
MAX_STORAGE_BLOCK_BINDINGS 96
TRANSFORM_FEEDBACK_INT_COMPS 128
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 0.5 - 10
LINE_WIDTH_GRANULARITY 0.125
POINT_SIZE_RANGE 1 - 189.875
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 3.0 CUDA 12.2.135
OpenCL Device NVIDIA RTX A5000
OpenCL Type GPU
Device Version OpenCL 3.0 CUDA
Frequency 1695 MHz
Compute Units 64
Device Address Bits 64
Global Memory 24563 MB
Max Allocation 6140 MB
Global Cache 1792 KB
Max Constant Args 9
Max Constant Size 64 KB
Local Mem Size 48 KB
2D Image Support 32768x32768
3D Image Support 16384x16384x16384
Max On Device Queues 4
Pref. Device Queue Size 256 KB
Max Device Queue Size 256 KB
OpenCL Platform Extensions:
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
cl_khr_3d_image_writes
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_khr_gl_event
cl_nv_create_buffer
cl_khr_int64_base_atomics
cl_khr_int64_extended_atomics
cl_nv_kernel_attribute
cl_khr_device_uuid
cl_khr_pci_bus_info
cl_khr_external_semaphore
cl_khr_external_memory
cl_khr_external_semaphore_win32
cl_khr_external_memory_win32
OpenCL Device Extensions:
cl_khr_fp64
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_khr_gl_event
cl_nv_create_buffer
cl_khr_device_uuid
cl_khr_pci_bus_info
Loaded Packages:
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/apex.json
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/kinefx.json
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/package_dirs.json
C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5.json
Environment:
ACTIVETAKE Main
ADSKFLEX_LICENSE_FILE 27000@DESKTOP-VNQ0V0S
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Users\chanc\AppData\Roaming
COMPUTERNAME Z-STATION_01
ComSpec C:\Windows\system32\cmd.exe
CommonProgramFiles(x86) C:\Program Files (x86)\Common Files
CommonProgramFiles C:\Program Files\Common Files
CommonProgramW6432 C:\Program Files\Common Files
DEADLINE_PATH C:\Program Files\Thinkbox\Deadline10\bin
DriverData C:\Windows\System32\Drivers\DriverData
EFC_224936 1
FPS_BROWSER_APP_PROFILE_STRING Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING Default
H C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716
HB C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/bin
HFS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716
HH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini
HHC C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/config
HHP C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/python3.9libs
HIP C:/Users/chanc
HIPFILE C:/Users/chanc/untitled.hip
HIPNAME untitled
HOME C:/Users/chanc/OneDrive/Documents
HOMEDRIVE C:
HOMEPATH \Users\chanc
HOUDINI_DESKTOP_DIR C:/Users/chanc/OneDrive/Desktop
HOUDINI_MAJOR_RELEASE 19
HOUDINI_MINOR_RELEASE 5
HOUDINI_OS Windows
HOUDINI_PATH C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/kinefx;&
HOUDINI_QT_PREFERRED_BINDING PySide2
HOUDINI_TEMP_DIR C:/Users/chanc/AppData/Local/Temp/houdini_temp
HOUDINI_USER_PREF_DIR C:/Users/chanc/OneDrive/Documents/houdini19.5
HOUDINI_VERSION 19.5.716
HOUDINI_VIEWERHANDLE_PATH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/kinefx/viewer_handles;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/viewer_handles
HOUDINI_VIEWERSTATE_PATH C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5/viewer_states;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/packages/kinefx/viewer_states;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/viewer_states
HT C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/toolkit
HTB C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/toolkit/bin
INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
JOB C:/Users/chanc
LOCALAPPDATA C:\Users\chanc\AppData\Local
LOGONSERVER \\Z-STATION_01
MATERIALX_SEARCH_PATH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/materialx
MIC_LD_LIBRARY_PATH C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\mic
NUMBER_OF_PROCESSORS 96
OS Windows_NT
OneDrive C:\Users\chanc\OneDrive
PATH C:\PROGRA~1\SIDEEF~1\HOUDIN~1.716\python39\lib\site-packages-forced\PySide2;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/python39;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/bin;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/toolkit/bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\chanc\AppData\Local\Microsoft\WindowsApps;
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
POSE C:/Users/chanc/OneDrive/Documents/houdini19.5/poselib
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 85 Stepping 7, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 5507
PSModulePath C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC C:\Users\Public
PXR_MTLX_PLUGIN_SEARCH_PATHS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/materialx
PXR_MTLX_STDLIB_SEARCH_PATHS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/materialx/libraries
PYTHONHOME C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/python39
PYTHONUNBUFFERED 1
ProgramData C:\ProgramData
QT_D3DCREATE_MULTITHREADED 1
QT_LOGGING_RULES qt.svg.warning=false
QT_QPA_FONTDIR C:/PROGRA~1/SIDEEF~1/HOUDIN~1.716/houdini/fonts
SESSIONNAME Console
SIDEFXLABS C:/Program Files/Side Effects Software/sidefx_packages/SideFXLabs19.5
SystemDrive C:
SystemRoot C:\Windows
TEMP C:\Users\chanc\AppData\Local\Temp
TMP C:\Users\chanc\AppData\Local\Temp
USER chanc
USERDOMAIN Z-STATION_01
USERDOMAIN_ROAMINGPROFILE Z-STATION_01
USERNAME chanc
USERPROFILE C:\Users\chanc
windir C:\Windows
After reading log it seems one drive (I thought I completely removed) redirected my documents folder.
Houdini uses the OneDrive Documents folder:
But the HtoA installer is still using %HOME%/Documents.
We've got ticket  HTOA-2036 open for this problem.
// Stephen Blair
// Arnold Renderer Support
