Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
How to use stress attribute in Houdini to blend shaders in Arnold
1 REPLY 1
eddi_fuhrmann
283 Views, 1 Reply
Hello there...
I have a vellum sim in houdini with a mesh expanding and inflating. for shading i want to blend two
shaders according to the stress attribute when the mesh is stressed or relaxed...want to set it up with 2 shader/layer shader and tried like every user data node with the stress attribute to blend the 2 shaders... not able to get it done and i can´t find any tutorials or stuff to handle it..
greetings
Labels (3)
1 REPLY 1
chogstead
in reply to: eddi_fuhrmann
You have to promote the stress attribute from primitive to points on the vellum solver constraints output, then copy that attribute to your output mesh. You should be able to use the attribute with the user data node after that.
