Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
How to use an operator to override light settings in htoa
4 REPLIES 4
253 Views, 4 Replies
Hi there, I just discovered the functionality of Arnold operators in Houdini and was able to tweak some object parameters like 'ar_smothing', material assignment, etc but I was not able to override any Light parameters following the same principles, as well as changing a camera. What am I missing?
Labels (4)
4 REPLIES 4
Slava_91
delete "/*" on end in selection, this is not need for light sourcehoudini-djiixuz4uo.jpg
in reply to: Slava_91
Thank you, it worked! But is it possible to change the camera the same way? Still doesn't work for me...
Stephen.Blair
The Arnold options node usually does not have a name (because there's just one options node in an Arnold scene).
And operators may or may not work on the options node, depending on what you are trying to set. The options have to be loaded before the rest of the nodes are processed.
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
Well, I thought of switching from one camera or angle of view to the other on the fly, during an IPR session, as you do in Katana. But here I guess you have to use a separate OUT node for each shot and each camera.
Technology Administrators
