Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
How to render DeepEXR on Solaris
11 REPLIES 11
Message 1 of 12
th-watanabeX37U8
1747 Views, 11 Replies
I'm currently trying to render DeepEXR on Solaris using HtoA 6.0.1.0.
I found that the Render Var LOP and Render Product LOP have a Deep setting.
But I can only render regular EXR, not DeepEXR.
What settings do I need to render DeepEXR?
Thank you.
Labels (5)
11 REPLIES 11
Message 2 of 12
Hi!
You need to go to the render product and change the product type from "raster" to "deep". That'll make the outputted exr file deep and all AOVs deep AOVs.
Message 3 of 12
Thank you for your reply.
I immediately tried the Render Product settings and no EXR was output. EXR can be output by returning the setting to raster. Maybe something is still missing. I've attached the HIP file I used for testing and the rendering logs.
Thank you.
deepEXR_Test.hip.zip
deepEXR_Test_log.txt
Message 4 of 12
klausWDHQZ
in reply to: pal.mezei
Hello was a solution found to this? When I change the Render Product "Product Type" to deep, no image gets outputted. Do we need to change/add something else somewhere?
Message 5 of 12
Stephen.Blair
in reply to: klausWDHQZ
No, I got a deep exr with just Render Product > Product Type = deep
// Stephen Blair
// Arnold Renderer Support
Message 6 of 12
in reply to: th-watanabeX37U8
After setting Product Type to Deep, I get this error:
<b style='color: red;'>[14:49:20] No AOVs defined for render, not all delegates will function properly</b>
I do have rgba Render Var specified, it works in raster mode.
Anything else is required?
Message 7 of 12
Stephen.Blair
Yes, but is an EXR still rendered?
I've seen that "No AOVs defined for render" but the deep EXR was still rendered to disk.
// Stephen Blair
Message 8 of 12
  • Create a Render Product and change the Product Type to deep
  • Under Render Product > Arnold > Deep, set the deep driver parameters
  • Under Render Product > Arnold > Deep Filter, set the filter used for each deep aov (there is one filter for all the aovs used in a deep driver)
  • Set up Render Vars and add them to the Render Product
  • Under Render Var > Arnold > Deep, set the aov-specific parameters
An example scene is attached.
deep_rendering.hip.zip
// Stephen Blair
Message 9 of 12
thank you very much!
now its clear
Message 10 of 12
There is one issue with filename padding when rendering more then 1 frame via husk with -n parameter.
All deep file outputs are written to the first file of the sequence.
Not sure if its husk problem or "HdArnoldRendererPlugin".
Attached hip file and husk command
husk --make-output-path -f 1 -n 10 -R "HdArnoldRendererPlugin" --purpose "geometry,render" --complexity "veryhigh" --snapshot 1000 "..../usdrender_16736_32_6/__render__.usd"deep_rendering_v2.zip
Message 11 of 12
Stephen.Blair
I think you need to use <F> instead of $F
That works for the "non-deep" renders. And the deep too, but husk is crashing after the third frame, with no messages or anything (but I can see that it calls WerFault on Windows).
// Stephen Blair
Message 12 of 12
in reply to: Stephen.Blair
what can we do about that crash? is it Arnold issue or SESI?
