Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
how to render cryptomatte in Solaris
18 REPLIES 18
Message 1 of 19
awu2500
2215 Views, 18 Replies
I use a RenderVar to render cryptomatte aov in Solaris,it doesn't work
Tags (1)
Labels (1)
18 REPLIES 18
Message 2 of 19
Stephen.Blair
in reply to: awu2500
Not supported yet.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 19
awu2500
in reply to: Stephen.Blair
thanks Stephen , hope it can support that someday
Message 4 of 19
janik.otterbach
Any news here?
Is there a date when the render delegate will support Cryptomattes ?
Message 5 of 19
San-San-San
Cryptomatte appeared in render var filter parameter htoa 5.6.1.0screenshot-2021-06-09-164148.png
Message 6 of 19
david.ostler2WSX9
Anyone figured out how to use this?
Message 7 of 19
Cryptomatte is not supported yet. There's more to cryptomatte than the filter (AOV shaders in particular).
// Stephen Blair
Message 8 of 19
Creator4
Any updates on Cryptomatte support in Solaris? This is one of the only threads I've found that talks about it, and the last post was back in August so I figured I'd ask.
Message 9 of 19
Stephen.Blair
in reply to: Creator4
Support for imagers and cryptomatte depends on adding support for arbitrary node graphs. Some of that work is being done in https://github.com/Autodesk/arnold-usd/issues/964 during the current sprint
// Stephen Blair
Message 10 of 19
bogdan.amidzic
Any news on this? Should we switch to Karma?
Message 11 of 19
klausWDHQZ
Would like to know as well. Any update would be appreciated
Message 12 of 19
awu2500
is that mean Arnold will support cryptomatte at next release?
Message 13 of 19
Stephen.Blair
https://docs.arnoldrenderer.com/display/A5AFHUG/HtoA+6.1.2.0
  • First cryptomatte support : Cryptomatte can be setup through AOV shaders, but final frame rendering is currently supported only when the scene is exported to USD and rendered with kick (rendering cryptomatte with husk isn't supported yet) (HTOA-1591)
// Stephen Blair
Message 14 of 19
awu2500
thanks, I'll test that
Message 15 of 19
trashes
Hi to all,
I'm trying for the first time to render cryptomatte in htoa.
I can see RenderVar in typical crypto style , but it seems have no content. When I render exr, in nuke  I can't pick nothing, as if cryptoaov were empty.
Any idea?
thankyou
Message 16 of 19
trashes
in reply to: trashes
issue was the same AOV shaders path of custom aov (ambient occlusion). If I have both (crypto and ao) doesn't work.
There's a way to have several AOV shaders path? or merge crypromatte with others aov write at the same time?
Message 17 of 19
Stephen.Blair
As of HtoA 6.1.4, you can have multiple aov shaders.
Picker doesn't seem to support it, but you can type in the names of multiple ArnoldNodeGraphs
If you use auto-complete, don't leave the trailing slash on the aov shader name
// Stephen Blair
Message 18 of 19
trashes
with HtoA 6.3.1.2 doesn't work.
But if I put same path of AOV shaders, the same Render Vars Namespace in crypto hda and create cryptomatte shader to raplace standard name (cryptomatte shader), and I enable "Custom Output driver" I have in the same path both aov. It Works!
when I update htoa I will try it...thankyou Stephen
Message 19 of 19
awu2500
Hi,  Stephen, hou to render 16 bit half float cryptomatte exr with default  "arnold_cryptomatte_aovs"  node? I tried to change the datatype form 'color3f' to 'color3h' at the default script, but I just got a weird exr, some object became black,and can not be picked at nuke.
